Question about Tunturi T20 Folding Treadmill
E7. Elevation stuck and wont come down - Tunturi T20 Folding Treadmill
    New Friend:
  • 14 Answers
Sounds like there is either a malfunctioning button on the upper console, or a shorted triac driving the elevation motor(or other elevation control device) Can you see any part numbers on the motor control board? Make sure the tread is unplugged before looking around.
Posted on Oct 25, 2010
2 Suggested Answers
SOURCE:
SOURCE: The riser on my Tunturi T20 is stuck on maximum
Phil, I have had the same problem today.
did you solved the problem already?
Posted on Jan 30, 2010
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
2)Alternative:
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Error code e7 on trojen staminia 310 - already tried switching off and on again. I washed machine and mistakenly got the motor wet.
see the next steps. God bless you
ERROR CODE # 7
2)Alternative:
Nov 16, 2012 | Exercise & Fitness
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
Error code E7
Dear Sir:
This error is normally associated with1) Elevation Motor problem.2) Display doesnot light up
1)tigh the connector from elevation motor and clean 2) Adjust the Potentiometer 3) Lubricate the gear 4) Test it.
2) Adjust the Reed switch see the diagram attached 3) tigh the connector very weel and clean the reed s.and reset.
sincerely. God bless you.
Apr 22, 2012 | Exercise & Fitness
9.9T was on incline8.started jumping unplugged it. Has E7 on screen. What do I need to do
Hello, sorry to say it sounds like you may have to get a replacement elevation motor. The error message "E7" corresponds to the elevation motor being "out of range" as the manufacturer puts it!
What I would do is plug it back in and turn it on again. DO NOT GET BACK ONTO IT. Run it for a while and try to get the elevation back down to 0. If the elevation motor will not move then you definately need a replacement.
Bottom line is that you might be able to continue using it without the motor, but only on zero elevation. To be on the safe side, get a new motor.
Sorrry couldn't help further
Jim
Feb 11, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Tunturi T20 Folding Treadmill Logo
584 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Marvin
Marvin
Roger Paull III
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
