Question about HP Office Equipment & Supplies
Hp4680 officejet. It says it has a paper jam but there is nothing in the mechanism. The problem was caused by too thick paper jamming the paper feed.
  • HP Master
  • 7,733 Answers
Try here LINK.
Posted on Oct 24, 2010
SOURCE:
HP PSC 1500 series: printer says the "the cradle is jammed" tried tuning it on and off and adjusting the cradle. taking out the ink cartridges and putting them back in. nothing. Someone please help?
Did you check for a Paper jam? Even a little bit of paper can cause a jam and that is normally what your problem refers to.... using too thick of paper can cause this kind of error as well
Sep 07, 2013 | HP PSC 1500
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
HP4680 not feeding paper during alignment
Check and clear any piece of paper is on the paper feeder sensor will resolve your problem.
Revert back for more assistance.
Thank you for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Photo paper too thick causes jam
You said that the photo paper you used to use was 9 mil, which seems to be well within the product specifications. You don't say the actual size of the photo paper you are using now, just that it is too think. Have a look at the product's specification's page. Scroll down to the Paper Specifications section of the page and see if the paper you are currently using is supported. If not, you'll have to go with thinner paper. Here's the page:
HP's Product Specifications
Sep 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Postcards causing printer jam
I think the card is too heavy or too thick for the machine as when it prints it has to turn the paper. If the card is too rigid it is unable to bend causing a paper jam. Suggestion is to try a less grade of card.
Thanks J
Dec 15, 2007 | HP DeskJet 5650 InkJet Printer
Open Questions:
76 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
