Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
E521T Hi, I can relate here, where can you get the info on the light sequences which determine the fault? I have green flashing light and found the freezer fan black wire was broken, replaced the fan but now why does it seem the fridge forgot to work? fans working is it locked in defrost mode?
  • 27 Answers
Close freezer door, open fridge door and press the mode button
Posted on Jul 15, 2008
What does code 1640 no power to pin 1 mean
P1640 is Vehicle Security System/No Code from VSS Twice
Check for faulty electrical Circuit between ECM Harness connector and terminal no. 61 (blue/green wire) and TCM See image below any problems found repair circuit and go to step 3 if no problems found go to next step.
step 2
With Ignition tured off unplug ECM harness connector. connect SST 86 11 857 Test light (or equivalent) between ECM harness and connector terminals No. 01 (pink/White wire) and 61 (Blue/Green Wire) Turn ignition on and observe test light. Test light should come on for about one second then go out. If TCM has detected a fault, test light will flash 2 times a second. if operation is not as specified problem is TCM related. go to next step
Step 3
You made need a garage i'm a mechanic so this is for me Clear all DTC's. Drive Vehicle at Varying Engine Loads and RPM for 5 minutes. Recheck Scan Tool for any stored DTCs If DTC P1611 is present Substitute Known good ECM and retest system
I got this info from saab central forum do a search for it for more info . Hope it helps
Jun 04, 2014 | 1999 Saab 9-5
Our panasonic tv green light flashes
If your TV flashes green light..try to count how many flashes and what is the sequence to diagnose where exactly fault came from..
Dec 12, 2011 | Panasonic Viera TH-58PZ700U TV
Ihave a DLP Projection TV, Model Number 52SX4D. When I try to turn it on, in the operation indicators, the second light from the top flashes and then the TV shuts off?
Hi Brian,
The operation LED indicators on DLP Projection TV's also act as 'Diagnostic Indiactors'.
The flash sequence of these LED's indicate the appropriate fault - you will need to refer to your User Manual which should explain what each flash sequence means.
Generally, most faults on DLP TV's relate to either cooling (fan operation), faulty/expired lamp, or even a loose panel (lamp door etc) somewhere is not correctly secured, causing a micro switch to trigger a shut down.
If you don't have a User Manual, try downloading it from the manufacturer's website.
Hope this helps......
Nov 01, 2011 | Televison & Video
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
HOLD LIGHT FLASHES & TRANSMISSION DOES NOT ENGAGE
The bad news: your vehicle's computer has detected an internal fault in your transmission.
The good news: your computer may be flashing a fault code 'sequence' through the 'hold' light. Observe the code sequence to determine how many long flashes and short flashes occur - long flashes represent the 1st number, short flashes represend the 2nd number (e.g. 3 x long flashes - pause - 2 x short flashes, denotes code # 32).
If you are able to report back with a code of any sort, I may be able to advise the likely fault.
Cheers,
"If this has helped you in any way, please rate this solution"
Jul 02, 2010 | 1993 Mazda Protege
Can u help? tv will not come on. clicking noise and red light flashing????
the flashing sequence is a guide to the problem
2 flashes space 2 flashes to 9 flashes space 9 flashes
once we know these we can pretty much determine the problem. None are good of course! They are all faults that need a repairman to intervene. There is no magic fix!
Please reply and I will give you the answer based on the sequence
Nettiser
May 12, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Clean light blinks
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there was some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics1.gif mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen to heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that you will fill the dishwasher with hot water water instead of the cool water that is normally in the lines before the hot water from the hot water tank heats the line. This should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
Jan 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
598 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
