Question about Samsung Cell Phones
Hello. Got my samsung wave yesterday. Today I installed samsung kies on my pc and and linked the phone to it. When the phone was linked to Kies I got a request to oppdate fastware. Followed the step by step upgrade and at the end the phone should restart. It did so, but it just keep turning on and off constant. What can I do to fix this? Thank you in advance.
  • 2 more comments
  • strandsk Oct 24, 2010
    Sorry, I was talking about the phone Samsung Wave. It is constantly turning on and off after updating the fastware from Samsung Kies.
    Can't digit anything because it is turning off immediately after the background appears.
    Can't digit anything because the turn's off immediatelt after the background appears.
    ok...thanx :-)
  • Samsung Master
  • 19,396 Answers
Re:"It did so, but it just keep turning on and off constant."
If you are talking about the computer, and Windows does not start, but before completing startup, turns off and restart, that means that the system files used on startup have been corrupted by the software you were trying to install.
First step:
Turn off computer.
Disconnect any USB device connected to PC, including the phone.
Disconnect computer power cable. If computer is a laptop also remove main battery.
Restart computer with only display cable (IF PC), mouse and keyboard if needed.
If that doesn't work.
Try starting the computer in safe mode by pressing repeatedly F8 key during startup.
At a point you should get a screen asking you in what mode the computer must start. choose safe mode.
In Safe mode do a system restore to the day or to the entry before the problem occurred.
If the computer does not start in safe mode you will need a Windows setup CD.
Start the computer with setup CD inside, booting from Windows disk (you may need to change boot settings in bios).
Go through first installation steps. Ensure you do not choose to format the hard disk, and that you do not change partition if asked.
Say no when the setup ask if to start recovery console, that will not help.
Instead of choosing install new system, choose the option to repair previous Windows installation. That is a different option from recovery console.
If repair does not work, you will need to reinstall Windows.
In that case do an update install choosing a different Windows setup folder (call it win 000). Ensure you do not format disk. This will leave your data inside the hard drive.
Try starting in safe mode first.
Ginko.
Posted on Oct 24, 2010
  • 1 more comment
  • Ginko
    Ginko Oct 24, 2010
    Hi.
    First remove the phone battery and restart the phone without memory card.
    If that ddoes not work, take off memory card and SIM and digit *2767*3855# (SIM card out/no SIM card when you reset). This will do an hard reset, bringing back the phone to factory settings.
    You will need to install the software again after the reset, as all software installed after purchase will be removed.
  • Ginko
    Ginko Oct 24, 2010
    Hi.
    I know, it is a common problem.
    Wave do this quite often. If the phone does not stay on long enough to be reset, then it must be re-flashed. This is better done at the shop, they charge a small fee.
    If the phone is new you can get a free replacement calling the phone provides.
    Before doing anything else watch this youtube movie on the same problem.
  • Ginko
    Ginko Oct 24, 2010
    I wanted also to remind you that flashing the phone or doing operations like factory reset may affect the warranty from phone service provider.
    If phone is new, before doing anything else, call the mobile service company and report the problem, they will likely send a new phone in exchange.
SOURCE:
How do I retrieve photos from samsung e2550 in windows 10
The Samsung Kies program may work for you. Install the app (link below) then connect the phone with a USB cable (phone end is probably mini-usb - cord available at Walmart, 5 below, Dollar Tree, etc.). There is a Kies tutorial at the bottom of the download page.
http://www.samsung.com/ae/support/usefulsoftware/KIES
There have been some reports of Kies not working sometimes, so the other option is to get a mini-sd card, install in your phone, transfer photos there, and then to your pc.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 04, 2016 | Samsung Cell Phones
How too install on pc
Download Samsung Kies software for pc from http://www.samsung.com/ca/support/usefulsoftware/KIES/JSP
At the bottom of this page there's a link to Kies Tutorial which provides details for xchanging files between pc and phone through usb cable.
With Kies Air, you can do this via WiFi. Hope this helps.
Mar 24, 2014 | Samsung Galaxy Pocket
Samsung primo connect to pc as modem
download samsung kies and install it .connect ur phone 2 ur pc through data cable .open ur samsung kies and connect ur phone through it for internet.
Jul 21, 2012 | Samsung Cell Phones
How to connecte with pc
after plugging the usb cable you need to go to menu Settings Connectivity USB USB debugging.
or just choose to see the memory and set
Settings Connectivity USB Mass storage Set.
Or yhou can use Samsung Kies, which you need to install
In Menu mode, select 1 Settings Connectivity
USB Samsung Kies Set.
Mar 26, 2012 | Samsung Wave 525 Cell Phone
Hi Yesterday i upgrading my Samsung wave s8500 firmware. while upgrading internet connection is Disconnect and now my phone only shows one picture on display whenever i tried to USE it... PICTURE i.e One...
Step I: Download the latest version of Samsung Kies from official site of Samsung Kies. The latest version of Kies is: Kies_2.0.0.11044.
OR
You can download it from here: Samsung Kies Download Link
Step II: Open Samsung Kies and connect your Samsung Wave with PC (Wait for driver installation, if you have attached your phone for the first time with your pc)
As soon as Kies will detect your phone it will offer a prompt of new firmware update available, see the screenshot below
Firmware upgrade prompt
Click on UPDATE button
Step III: Now you will face a window of 'Agree to the Terms and Conditions." You can choose the option of save and don't save the information. This option is that, Samsung will store your information of IP and hardware specifications on their servers for 2 years. It is totally dependent on you, which you want to choose.
We would like to recommended you to choose "Allow saving"
Upgrade Terms & Conditions
Hit START UPGRADE button
Step IV: It is strongly recommended not to disconnect your phone from PC until the upgrading process is complete. So take care of it.
Within few minutes (depends upon the speed of your internet connection). Upgrading process will move on and will complete successfully.
Upgrade in Progress
Note: Don't use any options on your phone, while the upgrading process is taking place, your phone will be restarted. DON'T PANIC!
Your phone will come to working state automatically and your Samsung Wave is successfully upgraded to Bada 1.2
Jun 03, 2011 | Samsung Wave S8500 Smartphone
Dear Sir/ Madam, why i cant play farm ville on my samsung wave 525. While going to play they are showing a message that you need to upgrade your flash player. Plz revert back asap Thanx, Milind.
Farmville requires Flash 10 and your phone does not support it.
You can try updating the firmware on your phone to see if it will work. To update your Wave 525:
  1. Make sure you have Samsung Kies installed.
  2. In the phone, Go to Settings > Connectivity > USB > and change it to "Samsung Kies"
  3. Plug in the USB and wait for Kies to detect your phone. Once it does...if there is an update you will see "Update Firmware" on the bottom. Click it.
May 07, 2011 | Computers & Internet
Hello wie kann ich handy mit PC verbinden.was muss ich herunterladen?
1. Klicken Sie HIER. Dadurch werden Sie auf der Samsung Webseite Kies bringen.
2. Wenn auf dieser Seite, Blick auf die Links f?r die genaue Modellbezeichnung Telefon.
3. Klicken Sie auf diesen Link und laden Sie die Kies-Programm.
4. Nach dem Herunterladen Kies, f?hren Sie die heruntergeladene Datei und installieren Sie das Programm Kies.
5. Jetzt in der Galaxy S-Stecker an Ihren PC mit einem Mikro USB-Kabel (in der Regel mit dem Handy im Lieferumfang enthalten)
6. Die Kies-Programm wird automatisch gestartet, wenn das Telefon angeschlossen ist, oder Sie k?nnen den Kies Programm zuerst.
7. Sie werden in der linken oberen Ecke, dass es eine Verbindung herstellt zu sehen. Dann werden Sie M?glichkeiten, wie und was man zu synchronisieren wie angegeben werden.
May 04, 2011 | Samsung Galaxy S GTI9000 Smartphone
Can i install samsung kies to pc with out internet connection????????????
u need to install d following b4 d kies
  • Windows Imaging Component (WIC) - (wic_x86_enu.exe)
  • .NET 4
    just visit http://www.trickswindows.com/2011/09/how-to-install-samsung-kies-on-pc.html to get the DIY procedure
  • Mar 01, 2011 | Samsung Star GT-S5233 Cell Phone
    Battery on Samsung Wave does not last long even when the phone is not in use for a day, and does not last the day. Also can go down in a few secs. This happens even with internet off. Help!!!!
    Hi there, this is a known issue with samsung wave, that's why samsung released an update that should prolong the battery power. So if you really turned off all the power-hungry apps and services (like internet, wifi and music player) then go for the update. It's a firmware update!
    -Install Kies( can be downloaded from samsung.com) -Connect your mobile phone to your PC using the Samsung Mobile Cable -Run Kies, and it will guide you through the installation process
    Feb 28, 2011 | Samsung Wave S8500 Smartphone
    Cell Phones Logo
    122 people viewed this question
    Top Samsung Cell Phones Experts
    Felizardo Erilla
    Felizardo Erilla
    Bill Long
    Donni Steen
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
