Question about Samsung Washing Machines
I have a WF7708N6W that keeps coming up with a door fault and does not seem to be locking the door when machine is started and has also faulted mid wash for same problem. Is this something i can strip and repair or off to a repairer? thanks
  • brianw7843 Oct 24, 2010
    Fantastic, I smelt a "burning" smell about 3 weeks ago from the machine and just kept an eye on it but now I know what it was the swith has heated up and the contacts look burnt inside the plug, now to just get the part. Thanks so much
  • Samsung Master
  • 19,396 Answers
Hi.
You need to replace the door latch. Parts available here: WF7708N6W
On most Samsung, to replace the interlock mechanism (latch and switch), you need to remove the rubber sea. It has a latch mechanism and an electrical connector on one side. Part is pretty easy to replace. Part price is around Au$70.
Part can be ordered from BIG Warehouse, Allied Appliances, or calling directly Samsung at the number listed on the owners manual.
Regards.
Ginko.
Posted on Oct 24, 2010
  • Ginko
    Ginko Oct 24, 2010
    Hi.
    You are welcome. The door switch replacement is not a difficult repair.
    Let me know how it goes.
    All the best.
    Ginko.
  • Ben Kenobi Apr 19, 2012
    I have the same problem but mine has burnt out while locked any suggestions on how to get it to unlock so I can replace it?
SOURCE:
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
Zanussi IZ12 mid program door light comes on.
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint WMA30 Front Load Washer
'door locked button flashing'
The door lock flashing all time has nothing to do with the weather, or pipes freezing up, it is a fault with the washer.
It is unlikely to be a faulty door lock, but could be a broken door catch spring or door catch problem, make sure you can feel the door latch in securely.
the other probable cause a fault on the main pcb where you programme the washer.
Another prob that can occur is a fault on the mptor caused by the brushes shorting on the motor armature, this in turn can blow a track of the pcb, and giving you the flashing light prob.
I would start by checking the motor first, if you are satisfied that the door is closing o/k.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA13 door lock fault
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Oct 15, 2008 | Hotpoint WMA13 Front Load Washer
Time saver on my Hoover Hd Vision washing machine keeps coming on mid wash! Don't know how to cancel it.
my machine had the same fault and seems to be quite common. What I didwas remove the pcb behind the control panel buttons, its held on byseveral plastic clips and simply ensure the ribbin cable was making agood conection from this board to the programmer. My fault was either aloose connection or the pcb was not in the correct position either way,it now works perfect and only took 5 mins work @ no cost.
Aug 30, 2008 | Washing Machines
Machine stopped mid cycle - door light illuminated
this appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Sep 18, 2007 | Tricity Bendix AW1400W Front Load Washer
Washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
271 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
