Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
What if I have change the partition of before using one touch reccovery function? Can I still create a back up?
  • Lenovo Master
  • 32,281 Answers
Probably won't work. The best thing to do is to use a program called Partition Magic to change the your C Drive partition. After this is done, check to see if the Lenovo boots up properly, then create a back up.
Posted on Oct 24, 2010
  • Lenovo Master
  • 11,800 Answers
Yes, no problem, just that you will have to reconfigure the backup software again.
SOURCE:
Deleted partition recovery
You may recover deleted partition from Transcend USB drive with data recovery software, download from
http://www.asoftech.com/articles/transcend-data-recovery.html
hope this helps.
Nov 27, 2013 | Transcend StoreJet 25 Mobile 500GB USB 20...
Tip
How Do I Correct the Error and Recover an Acer Computer hard drive?
In order to correct the hard drive partitions so the recovery program will work, you can use a variety of tools listed below.
1) [email protected] KillDisk - Use their free killdisk program to wipe the hard drive clean off all partitions.
2) Ubuntu or another Linux alternative bootdisk. Create a boot disk for the Ubuntu Live CD and boot the computer from it. During the boot process it will ask to "Try Ubuntu without any change to your computer". This is the option you want. Once Ubuntu loads, find the partition editor program under the System, Administration menu..
To delete a partition, right click on the partition that you wish to delete and select "Delete" from the menu. Once you are sure that you've selected the correct partition, and are positive that you have backed up all the files or data that you wish to save from that partition, click the "Apply" button at the top of the Window, and the partition will be deleted.
3) Use the Acer Hard Drive Format Utility, on some versions of Acer computers when you have the option to create Recovery disks, the system creates a hard drive format utility CD as well. Boot from this CD and format the hard drive.
The utility will recreate 1 partition (C: drive), after the partition has been created, you'll be able to reload the HDD with the backup media. The file is an ISO image for CD media only (not compatible with floppy diskettes). Create a CD disc from the ISO image file using a CD writer program on another computer.
Once the hard drive partitions have been deleted by any of the utilities above, you can proceed with rebooting the computer using the Acer System CD and proceeding with the complete recovery of the system.
on Jun 25, 2010 | Computers & Internet
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
Apr 16, 2013 | Lexmarkr X646E Multifunction Printer -...
Can't create partition
Purchase or download a partition manager program. The only way you can easily manage or change your partition is to get a third-party program. Partition Magic Freeware is the most widely known partition manager software. http://www.filehoo.com/download/Partition-Magic-8,0.aspx
You can also download freeware programs such as Cute Partition Manager. http://download.cnet.com/cute-partition-manager/3000-2094_4-10605516.html Open or run the partition manager. In Partition Magic you can open the program easily. In Cute Partition Manager you may have to create a boot disk and boot from it to run the program. Once the program is open, select the drive you want to manage. Go to the menu and choose an action or right-click and choose "re." There will be an action -menu that will let you choose something like "re" or "change hard drive ." Some programs will also let you right-click on the graphical expression of a drive and choose the action or drag the graph to change the . Pick a new for the drive and decide what you want to do with the remaining space. The rest of the space should be partitioned or formatted to make use of it if the current partition is downd. Apply the changes by clicking "apply" or "OK." You will then have to reboot the computer for the changes to take effect. The program may automatically do this for you or it simply may direct you to do it. With the new ReadyBoost feature of Microsoft Windows Vista and Windows 7 operating systems, as well as with various server operating systems, you can create a partition on many external drives to use for a virtual memory swap file location, speeding up the computer for many memory-intensive tasks or for systems that are short on RAM.
Back up any data currently located on the drive prior to creating, deleting or changing partition or otherwise attempting to configure the USB drive. Open "Computer Management" under the "Administrative Tools" section of the Control Panel. Click on "Disk Management" to display a list of drives and their current partitions. Right-click on the drive and choose "Extend Volume" to make the partition larger using available space on the drive; "Shrink Volume" to reduce the of the partition, freeing up space on the drive; or "Delete Partition" to remove all partition information and to create fresh partitions on the drive. Right-click on the free space on the drive and choose "New Simple Volume" if the existing partition has been deleted. Click "Next" and then enter the desired of the first volume on this disk. Choose to assign a drive letter, assign the partition to its own folder on an NTFS volume or not to assign a letter or assign the partition to a folder if the drive is going to be used on a different system. Click "Next" to display the format dialog screen and choose to format the drive using the default settings. Give the volume a name and click "Next" again to review all of the chosen settings. Then click on "Finish" to begin the format process. Repeat the partition creation steps for as many new partitions as are desired on the drive.
Jan 21, 2012 | Kingston Computers & Internet
How to partition. appreciate a step by step instruction. thanks
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
i have used this and found it a very good program and is easy to install
hope this helps you
Aug 20, 2011 | Seagate Freeagent Goflex Desk 3 TB Desktop...
Pls help me to partition my hard disk drive as c and D
If the computer is already running with Windows, then you can use a program called Partition magic to partition the C drive into two partitions - a C and a D drive.
If you are installing Windows from scratch then you can use the Windows installation CD to install Windows. When the Windows installation begins, delete the existing partition, then create a new partition but size the 1st partition (C drive) to what you require and continue with the installation.
When Windows has finished installing you can create the D drive by opening Control Panel - Administrative Tools - Computer Management - Disk Management - click on the un-partitioned portion of the hard disk, create a extended partition - and then format this partition in NTSF When completed Disk 1 will be shown as Healthy (system)
Mar 20, 2011 | Computers & Internet
Unble to formate the pendrive
Free Partition Software - MiniTool Partition Wizard Home Edition home1.png MiniTool Partition Wizard Home Edition is a free partition manager software designed by MT Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista and Windows 7. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions, Copying partitions, Create partition, Delete partition, Format partition, Convert partition, Explore partition, Hide partition, Change drive letter, Set active partition, Partition Recovery.
Dec 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
Aug 05, 2009 | Acer Aspire 6930-6771 Laptop
HP wont reformat due to no user partition?
it often ask for a petition size make sure you select one smaller that the available disk space.
Jul 18, 2009 | Gateway MX6920 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
