Samsung pcj522r Could not find the stk392-040. I took the back off are they one one of the three boards on bottom or mounted to sides?
  • 8,617 Answers
I just posted a response so you can locate the ICs
Posted on Jun 07, 2008
Samsung pcj522r
If they tested the convergence board and thats ok, the only other Items it could be are the Digital convergence unit or the Velocity comando units that control the convergence yokes. If the convergence isnt adjustable with magic focus adjustments wont help it. Is the repair shop an authorized samsung repair facility? If you need more assistance let me know.
Jul 26, 2008 | Televison & Video
Samsung pcj522r
no but the board which is on the upper neck of the green CRT could its the velocity board which has an effect on all 3 tubes convergence.
Jul 20, 2008 | Televison & Video
Samsung pcj522r blue converence
You can get the replacement Ics at the following link you need two STK392-040 ICs they are located on the Convergence board that should be mounted on the upper right side of the set above the deflection board. You will notice two large Black Ics with STK392-040 stamped on them. Heres the link to get the new ICs and free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | Televison & Video
PCJ522R 52 /Power Deflection Board
we can give you a quote on what we can rebuild your deflection board for if you go to this link and send us an email request stating model nuber and part number of the board you need rebuilt. all our boards are completely rebuilt and are guaranteed.
Heres the link.
Mar 24, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
T.V.
Afraid you have the Bad Samsung set The convergance Ic's are mounted below ot a differant board that I described. If you are good at soldering simply replace the Ic's STK392-040 there are two, if you simply want to replace the entire board the part number for youre set is AA95-00055E and it's about $250.00
Feb 13, 2008 | Samsung PCJ522R 52" Rear Projection...
Bad color, blurry, hour glass screen...
This is the most common problem with projection based sets, what you have is known as convergance failure. There are two Ic's and in a Samsung they are STK392-040's these will need to be replaced and possibly a small fuse and a few resistor. I am haveing trouble with the moidel number you gave and cant quite nail it down, but some Samsungs put these all on a easly replacable board. This board BP95-00142E is about $80.00 and avalible at www.vancebaldwin.com A easy way to tell is remove the back and see if these huge Ic's STK392-040 are mounted separly from everyother board and are mounted to the crt mount
Samsung PCJ522R Pictures is completely shaded with yellow
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Oct 25, 2007 | Samsung PCJ522R 52" Rear Projection...
SAMSUNG PCJ522R 52IN Rear Projection TELEVISION WILL NOT P OWER ON
1)Check PC boards for CRT coolant leak.Look closely at the
signal board and the main/power PCB.
2)Check any/all fuse devices in power supply
3)Let me know your findings....T.
Oct 23, 2007 | Samsung HCN4727W 47" Rear Projection...
SAMSUNG PCJ522R
part numbers AA91-00607A and BP96-00645A the Bp part number is the bag hoses and ends for all three CRT's sold in a kit form and has all you need
Aug 30, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
