Question about Sony E-reader Portable E-book MP3 Player
I have lost the instruction manual for my Sony E reader touch edition PRS-650. Is it possible to get a replacement on line?
  • Sony Master
  • 4,924 Answers
Http://esupport.sony.com/US/perl/model-documents.pl?mdl=PRS650
here is the support site for your model , you will be able to find drivers software and manuals ...on this page ..
Posted on Oct 24, 2010
SOURCE:
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Prs 600 ereader screen contrast problem
The PRS-300 "Pocket Edition" ereader is a device that did provide a far better than ... I bought the Sony Reader Pocket Edition to use for my public library's downloads. ... Conservatively, I probably read upwards of 20 hours each week, both ..... Well lets just say it only seems like there are a few words on the screen at a time. ...
Jan 03, 2012 | Sony Reader Touch PRS-600
I have been given a Sony reader but no instructions so dont know how to use it
You can find your manual as well as any support you require from the following link:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PRS350
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Sony Reader Touch PRS-600
How do you get the sony prs-600 off demo mode?
Hi.
Please look at this document from Sony's official site with instructions on taking the PRS-600 out of demo mode.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1006375
Apr 04, 2011 | Sony Reader Touch PRS-600
My daughter purchased a Sony Reader Touch Edition (PRS-600) some time ago and used it for a while then gave it to me. I tried to use it myself but when I attempted to download a book that I had purchased...
Remove the reader software from your computer first. Then reinstall the eReader software, the sync the eReader to the program while in the Sony store window; set up an account for just you via the Sony store and start spending money... enjoy!!
Jan 07, 2011 | Sony Reader Touch PRS-600
Prs 650 stuck on sleep mode, wont charge or connect to pc
Please click hear to get the information to resolve the issue.
Please click here to get clarification from my side.
Thanks.
Jan 02, 2011 | Sony Reader Touch PRS-600
How do I download music to my sony reader prs 650
Personally, I find the Digital Library interface for Sony is slow, cumbersome and irritating.
I found the quickest and easiest way to get files on to the e-reader is to load any files you want to use on to a SD flash memory card on your PC. Then, make sure your e-reader is totally switched off, not just in "Sleep" mode. To do this slide the "Off" switch over and hold it for 2-3 seconds and confirm "Yes" when asked. Then insert the SD card in the e-reader. When you power up the reader again you will find the files show up in menu system of the reader.
Oct 26, 2010 | Sony Digital Reader Touch Edition
How do I change he brightness on the Sony touch edition
There is setting available in the Reader to change the brightness on the PRS600 Reader,.,...
Feb 01, 2010 | Sony Reader Touch PRS-600
Sony E-reader Portable E-book MP3 Player Logo
151 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
