Question about Belkin (F5D7230-4) Router (587009)
After enjoying wireless connection thro' this router for the past year i find that it will no longer give me a wireless connection and i have had to revert back to the old method of connecting. My question is two fold , one - can i use the reset button on the bottom and just go thro the motions as i did originally when i first connected it . And two - to use the re set button do i just press it with a pin or what ? looking forward to your help John D
  • Belkin Master
  • 32,281 Answers
Yes, you can change the router back to the default settings by -
power up the router, then press and hold the pinhole RESET button with a sharp point for 7 secs.
The default password = blank (just press Enter)
Posted on Oct 24, 2010
SOURCE:
Linsky router has been connected for a year and working fine but within the past 24 hours even though the signal is strong for connection it will not permit us to go wireless on the laptop or son's XBOX...
can you access the Linksys page while on wireless even if it gives you page cannot be displayed error when you browse?
try to do a hard reset on the router and reconfigure your wireless connection. just press the reset button for 10 seconds to reset it properly.
Jan 27, 2011 | Linksys Wireless-G Broadband Router
How do i connect to xbox live and do i need an email address
yes you need a email connect thro modem or router eternet port or use a wireless adapter and find your signal in system settings ok now click on join live and it will walk you thro the easy steps to join
Dec 05, 2010 | Microsoft Xbox 360 Console
We recently got a new laptop with Windows 7. The wireless connection worked for a while. But now our wireless network is no longer visible to the laptop. The only network available is named Linksys which...
Did you try to reset the router ?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Sep 12, 2010 | Linksys Wireless-G WRT54G Router
Router works well most of the time....then for past two weeks it won't rout to other 2 PC and will not allow me to access modem. If I disconnect and plug in direct to PC modem works. Called high speed...
I have had similar problems in the past with 3 different brands of wireless routers, including the linksys Wireles-G router. In all cases, it was the same scenario, worked fine for a year or so, and then started giving inconsistent intermittent connectivity problems. Resetting, recycling etc. etc. would work for a while and eventually it would become unusable, and I would end up replacing. I went from a D-Link wireless router, to a Belkini, to a Linksys, and now use the Apple airport wireless, which I have also recently replaced with another Apple airport wireless. So unfortunately, I can't tell you if it's me doing something to kill them or if they are just short life expectancy for wireless routers, but the only fix I have experienced is replacing the router. Good luck...
Aug 30, 2010 | Linksys Wireless-G WRT54G Router
I set up my laptop using a Belkin wireless router, and it is o.k. thro ethernet by does not recognise wireless when I disconnect the ethernet cable!!
Well the best shot is to reset the router back to factory by pressing the reset button for 10 seconds then it will flash a couple of times. then see if your laptop can connect to the router, If that doesnt work let me know
Nov 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless Network Connection is no longer connected
I've had this problem before. Simply power cycle the device (unplug it, wait 20 seconds, and plug it back in). If this starts happening often it may be nearing the end of this products lifecycle (you may need to replace it). I had mine for 3 years before I had to replace it.
May 21, 2009 | Linksys Wireless-G WRT54G Router
I have started to not be able to connect two
hello,
i belive i know what is happening
what is happeing is that ur router is giving you the same IP address to both your computers this happens alot when you have a network,
what you would have to do is call the manufature of that device the one giving the wireless signal then tell them that your the router is giving the same ip´s to both PC´s or laptops and they would force the ip´s depending on the settings that you would be using at this time
, JULY
rate my service please
Apr 11, 2009 | D-Link AirPlus DI-614+ Wireless Router
Cant get a wireless connection
hi,  its an common prob, .  first u need to know that everytin s jus perfect,. try connectin thro lan first,. if ur lappy achieved de connec, then its de prob of the settings of connectin thro wireless,,. so change ur settings accordingly and try set up an new clean connection,,. thank you,.
Mar 14, 2009 | Computers & Internet
MY WIRELESS LINSKYS HOOKED UP NOT FINDING MODEM/CANNOT CONNECT
You don't use a modem to connect with a wireless router. Connect an ethernet cable between the laptop and the router to ensure that both are working. If this gives you an internet connection then the commonest problem is an incorrect wireless key. Reset the key on the router then cut and paste it into the wireless network setup in the Control Panel. Wireless drivers are frequently updated and you should check for a newer driver.
Feb 02, 2008 | HP Compaq Presario C304NR Notebook
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
