Question about GE 106591 Coffee Maker
GE 169103 I purchased a GE 16901 Coffee Maker and Grinder with just stopped brewing. The clock is working but it won't brew and I can't find the instruction manual, does anyone have one they can copy or know where I can download one?
Make sure all the pieces are put in properly, and make sure the lid is snapping when it closes. If it doesn't it won't work at all!
Posted on Mar 29, 2009
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
I have a GE coffee maker and grinder model no. 169103...Use only 20 times went to turn it on nothing happened.
I just got the 169103 coffee maker off e-bay.
Got it home and found it would not come on.
I did get my money back,,,however, decided to open up the bottom and found that the power connection to the unit gets very hot. The cord was burned. I managed to re-do the connection and it works now.
Oct 29, 2009 | GE 106591 Coffee Maker
Grind Off light blinking
Mine was doing that for the past week. I think it was indicating there had been a power outage but that the clock had not reset to zeros. I changed the time a couple of minutes and it stopped.
Sep 24, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
GE coffee maker with grinder 169103
We were unable to find a coffee pot that fit this model after it was broken so my roomate devised a solution to make it work in the meantime. He took the little plastic tab that closes off a bag of bread and used it under the filter in the filter cup to clip around the devise that holds the brewer open and let the coffee pour out below. Then we used a four cup Pyrex measuring cup underneath to catch the coffee. The first time I tried this without the device the coffee flooded out of the pot and all over the sink and not in the Pyrex because I didn't realize the previous pot held this device open. Just remember to let it finish brewing because it doesn't shut off when you remove the pot once you rig this up. A paper clip might work also. Good Luck!
May 08, 2008 | GE 106591 Coffee Maker
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
GE 106591 Coffee Maker Logo
182 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
