How do i send a fax to ireland from australia? wat codes shud i be dialing. i need to no asap
    Genius:
  • 1,218 Answers
Go to your phone book ..in the front they normally have all the codes for international calling.
Posted on Oct 24, 2010
SOURCE:
I want to fax from new zealand to australia. how about i do it...........
In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
??  The "+" (plus) character (by pressing
key)
??  Your Country Code( "64" for New Zealand)
??  Your local area code minus any leading "0"
??  A space
??  Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
??  You cannot enter a hyphen in the number.
To enter a space press once between numbers.
??  The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
Jun 02, 2011 | Brother IntelliFax-2820 Laser Fax
I need to send 1 fax to several recepts
You can send a fax to up to 142 fax numbers, using any combination of dialing methods:
- One-touch Speed Dialing (up to 32 destinations)
Press the desired One-Touch Speed dial button(s)
- Coded Speed Dialing (up to 100 destinations)
Press [Coded Dial] > enter the 2 digit code (00-99) using the numeric buttons and be sure to press [Coded Dial] before each code
- Regular dialing and redialing (10 destinations)
Enter the number using the numeric buttons or [Redial/Pause] and be sure to press [Set] after each entry with the numeric keys
After all the numbers are listed, press [Start]. The machine will scan in the document (memory) and then begin sending it to the destinations in numerical order, starting with One-Touch, then Coded and finally the numbers dials with the numeric keys.
You can also create a group if you frequently send faxes to the same group of people by first saving them as One-Touch and then adding them to a new group.
Apr 13, 2011 | Canon FAXPHONE L170 Plain Paper Laser
I need the instruction to set the machine right for sending a fax from Cambodia to Australia or receiving a fax from Australia. I typed number in Australis to send a fax but my friend there did not receive...
There is not much to do than to set the machine in the fax mode after setting up the time and data as instructed on the interactive menu .
You need to type the STD code of cambodia and the number of the fax there which must also be active. Make sure that you enter the correct local code if the number is in sub-district.
Ask your friend to send the fax after placing your machine in fax mode.
Make sure there is dial tone and you are able to make calls using the telephone mode.
if not check the connection.
Feb 15, 2011 | Brother MFC-7340 All-In-One Laser Printer
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
International Faxing??
you need an international phone service and dialing capability on your phone, the country code for Australia is 61 so you would dial:-
011-61- Y- xxxxxxxx where 011 is international code from USA, 61 is country code Y is area code and xxxxx is fax number.
Just dial the number as sending a local fax
Dec 15, 2009 | HP 1040 Plain Paper Inkjet Fax
I need a fax sending from australia to england but unsure what the international code is for faxing and what numbers too take out, the uk fax number is 01803 521785....please help?
A fax is nothing but a normal homestyle phone line. Either go online to find a list of country codes or call your local operator for assistance.
Sep 22, 2009 | Office Equipment & Supplies
Calling overseas from Australia to UK on a Uniden 9035 handset
Just dial 0011 then the country code. The + is just a quick way of dialing 0011.
Also these can be used from Australia 0011 (Voice calls)
0015 (Fax calls - Telstra)
0018 (Telstra special rates)
0019 (Fax calls - Singtel Optus)
go to http://www.kropla.com/dialcode.htm full a full list of international codes
Dec 01, 2008 | Uniden Cordless Phone
2410 xi all in one printer will not let the phone hang up in the fax mode
Thanks for the additional info.
First of all, if you live in any of the following countries, you must make sure that you use the 2-wire phone cable that came with the printer instead of standard phone cable:
Argentina, Australia, Brazil, Canada, Chile, China, Colombia, Greece,
India, Indonesia, Ireland, Japan, Korea, Latin America, Malaysia, Mexico,
Philippines, Poland, Portugal, Russia, Saudi Arabia, Singapore, Spain,
Taiwan, Thailand, USA, Venezuela, and Vietnam.
Secondly, I would strongly suggest that you download the latest copy of the users manual for your machine from the link below. Make sure that your connections are the same as those in the manual. There are also troubleshooting steps that are simply explained in the back of the manual:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
The next thing to be sure of is that there is a dial tone at the phone that is built into your fax machine. If you are on a VOIP system (in other words, if your phone service comes into your home via your cable TV line or the cable company provides your phone service), then the cable modem/router must be configured to provide a dial tone to the outlet the fax machine is plugged into. To test if a dial tone is present, simply follow the normal fax procedures (they are also in the manual). When you tell the machine to fax, you should hear a dial tone just before your hear the tones of the fax number being dialed. If you don't, then your problem is with the cable company.
Sorry for the long-winded answer. Please let me know if this helps!
Bob
Oct 08, 2008 | HP Photosmart 2410 All-In-One InkJet...
270 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
