My washing machine stopped spinning and displays LE on the digital pad.help me out
    Sergeant:
  • 239 Answers
Dont know what brand you have mostly LG. LE error is hall sensor is bad
Posted on Oct 24, 2010
SOURCE:
LG WM2350HNC Front Load Washing machine displays LE error, I have tried cleaning it and flushing the drain hose out and the filter., still will not work... Tub tries to spin but can't... It is only...
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. What is the model number listed on the machine? The number posted was for a range.
Nov 14, 2012 | Washing Machines
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Apr 11, 2011 | LG WM1812C Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Washer does not spin and displays an LE error
LE is lock error..This most commonly means that the interlock is faulty...This is component which stops the door from opening during wash, and allows power to the machine when the door is shut..Replacement probably needed..Not a big job...Good luck....Nomess
May 22, 2010 | LG WM-2277HW Front Load Washer
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
New washer not washing
Unplug the machine for about 20 minutes so the computer can reset. First load?? Machine is under manufacturer's warranty get hold of the company who sold it to you - ask for a replacement.
Sep 15, 2007 | Washing Machines
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
