Question about HP Compaq dc7600 Small Form Factor PC Desktop
162 - system options not set and i cant goto setup window by press F10
4 Suggested Answers
SOURCE:
  • 28 Answers
SOURCE: How to do the CMOS setup in HP Compaq DC5100 SFF (PM215AV)
Common  keys are delete, f1, f2, f3 , f5 , f10 , escape and insert If these dont work, then check on Hp's page for your computer; you should be able to download a manual.
Posted on May 23, 2009
  • 5 Answers
If you changed the battery on the mother board you erased all the setting on bios. You will have to enter Bios setup by usually hitting "DELETE" button. and reset to default options. Every Bios setup looks diffrent.
  • 1043 Answers
SOURCE: OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Posted on Jul 10, 2009
I've got a dc7800 Small Form Factor system. After less than a second, a blue window"smart card authentication" and below that, "smart card reader not present".
"System Options Not Set" normally means that the battery that maintains those options has gone dead. That's usually a 2025 coin cell on the motherboard.
I would replace that first thing, then set the BIOS options. Usually, there's another message that comes up, "Press F1 to continue, F10 for setup". F1 will let you system boot, most likely, but doesn't set the options. F10 (or whatever it says) will get you to where you can set the options.
Nov 09, 2015 | Computers & Internet
How to restore my compaq nc8000 to factory settings
Hi, When your system restarts displays message to enter in setup mode. Whatever it shows KEY to enter like F10 or F12 to enter setup, press the key and enter into setup then select Restore Factory Setting by selecting the option from the list.
Thanks,
Regards
Apr 05, 2013 | Computers & Internet
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
How do i restore my c650 back to factory settings as i cant access my desktop because i changed my windows password and forgot it
Hi
If you want to use the recovery disk to reset all to Factory settings, you need to press either F10 or F11 when you start the Laptop.
Switch laptop on and start pressing F10 once every 2 seconds till you see the recovery starts. Then follow the recovery wizard.
If F10 does not work try the "F" keys usually the F8 takes you to safe mode options and F12 to the Bios setup.
Hope this helps
Feb 15, 2011 | Toshiba Satellite C650DST2N02 Laptop
Zenith director laptop, after switching on the system, press F2 for bios setup and F12 for boot setup screen appears and hangs up. What to do?
If you need to boot your cd you not need to press F12 just after entering bios setting goto boot configuration and change your first boot device to cd\dvd and press F10 and select yes.
Dec 08, 2010 | Computers & Internet
My PC doesn't load
Restart computer. Watch closely at the bottom of the screen for an F command.
This F command will allow to enter setup.
When computer is loading, start pressing F12 repeatedly until setup is opened.
When setup opens, you'll see a file menu that runs across the top of the screen. It will start from the left and move to the right - press F9. When prompted, select "restore default settings". Move to each file menu and press F9 and set "default settings".
When you come to the Exit menu, do the same thing, then select the Exit Menu, and choose the "Exit Saving Settings" option.
Once it exits, it will automatically restart and begin the loading process into Windows (or your operating system).
If the OS does not load, you will need to re-enter setup: under the file menu, search for an option that will allow you to enable a second F command which should be F5 or F10. Once this is done, go to exit, and select "exit saving settins".
The computer will begin loading, but you will want to restart the computer - watch again at the bottom of the screen for the new F command - remember what it is when you are in setup, and begin pressing it as before with the F12 command - the F5 (F10) will bring you to an option menu for starting the computer - select the "start in safe mode" option.
If the computer does not load in safe mode, you will need to format the hard drive and re-install the Operating System.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 23, 2010 | Acer Aspire m5640 PC Desktop
Restore back to factory settings
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 11, 2009 | Acer Aspire 5535-5050 Notebook
May 23, 2009 | HP Compaq dc5100 Small Form Factor PC...
HP Compaq dc7600 Small Form Factor PC Desktop Logo
281 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
