Question about Individual Hanes T-ShirtMaker Deluxe Full Version for PC
Steps on how to tie dye a t shirt - Individual Hanes T-ShirtMaker Deluxe Full Version for PC
    President:
  • 2,340 Answers
Here some sites should help, Link 1, Link 2
Posted on Oct 24, 2010
SOURCE:
Tip
How to Tie a Tie
The knot that will be taught is called a Pratt knot, aka the Shelby Knot. It is a simple, easy to do knot that looks good with almost any shirt and tie combination.
Step 1) Start with the tie inside out, and the wide end about a foot further down than the narrow end.
Step 2) Cross the wide end under the narrow end.
Step 3) Make a knot by bringing the wide end up and through the intersection of both ends.
See the picture below, it will make more sense.
Step 4) Experiment a little to tighten and raise the knot up to your collar.
Step 5) Once the knot is raised, cross the wide end back over the narrow end and bring it up through the collar, as shown.
Step 6) Now, take the wide end you just pulled through and bring it down through the loop, on top of the narrow end.
Step 7) Now, tighten and adjust accordingly, and you're done!
on Apr 14, 2011 | Office Equipment & Supplies
Make a kids cape
Use any rather large piece of cloth like a bed sheet, curtain, table cloth, etc. You can just dye it black or whatever color you need if the material is not the color you need for your kid's cape. Trim/cut to size needed, sew raw ends. Just fold 3/4 of an inch to the top part where you will can in some ribbon to be able to fasten the cape around the neck. An option instead of tying around the neck, would be to gather the tops and sew in place then attach to the shirt or costume using velcro.
Jun 29, 2014 | Clothing Accessories
How to tie fabric for tie dye
The art of tie dye has no boundries. It all depends on how big of area or how tight you make the knots. You can make one big one and be done or you can repeatedly tie tighter as you die or looser.....get crazy. Tie dye is.
Jan 29, 2013 | Sewing Machines
How do i set color on tie dyed t-shirt? color is running each time i try washing it
my mam told me to steep them in salty water before puting into wash old wives tail but it worked for me but most home dyed stuff the colour will run hope this helps ivan
Sep 28, 2012 | Washing Machines
Hi, can you teach me on how to use jobos dye. Appreciate if you could the complete step by step... Thanks
For this project, we will be making a basic sunburst design on a t-shirt.
  1. First, wash the -shirt in order to remove any possible dirt and prepare it for dye absorption. Tie-dying is best done on damp fabric.
  2. Cover our work area with newspaper to protect it from any spills, and assemble all your tools.
  3. Wear rubber gloves to prepare the dye. Carefully follow the manufacturer's instructions provided on the package.
  4. Our particular fabric dye, Venus, for example, calls for the powder to be dissolved in boiling water to get the best, fastest results possible. So fill the large container with lukewarm water, bring to boil, and pour in the dye, starting with the lightest color if you are using more than one color.
  5. While the water is coming on a boil, lay the t-shirt flat on your work area. Grab the center of the t-shirt with your thumb and index finger, and lift it up. Run your other hand down the cloth, twisting the fabric as you gather it together tightly.
  6. Wrap one rubber band around the gathered t-shirt, right below the spot where you lifted. Then, wrap a few more rubber bands, about one to two inches apart from each other. Feel free to make up your own spacing.
  7. Once you're satisfied with the rubber band placement, immerse the entire t-shirt in the first color dye. Boil the t-shirt for 10 minutes , stirring constantly. Then, stir 4 level tablespoons of salt into the mixture for each gallon of water used. Boil for another 20 minutes, stirring constantly.
  8. Remove the t-shirt and rinse in cold running water. Wring out the garment until water runs almost clear.
  9. For designs requiring more than one color, repeat steps 3 to 8, using colors in order from lightest to darkest.
  10. When you have finished dying the garment, remove rubber bands and lay t-shirt flat on your workspace. Place a towel over the still-damp garment, and iron it flat.
Feb 10, 2011 | Garden
White shirts have grayish stains
try soaking the shirt with ritz's white dye.
Sep 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Colors flashing no picture
Did you have another monitor to verify the problem whether it is related with the Video card or the monitor itself?
Jul 29, 2007 | Xerox XG-71D 17" Flat Panel LCD Monitor
Individual Hanes T-ShirtMaker Deluxe Full Version for PC Logo
123 people viewed this question
Top Individual Computers & Internet Experts
john smith
Peter Dragonetti
Vebble
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
