Hi a vertical pixel line has appered on my philips ambilight, is it repairable or not?
  • 998 Answers
The vertical pixel you see in your lcd is a dead cell it is not fixable but you can replace your lcd.
Posted on Oct 24, 2010
  • matthew_lock Oct 24, 2010
    The tv is a plasma not LCD does this make a difference and how much to fix?
  • Noel Jucutan
    Noel Jucutan Oct 25, 2010
    sorry. one of the module in your plasma is defective, this module is the one that producing the image in your screen it is reparable. the price is much cheaper than the lcd. try to contact a technician to check the problem personally.
SOURCE:
I think the inline fuse has blown,we're will I locate this fuse? Thank you.
Get in touch with support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Mar 10, 2015 | Philips 46PFL9705H 46-inch Full HD 1080p...
Plz my philips 3d tv(ambilight)46 inches when it is powered,only the ambilight comes on and then goes off after few seconds,but displays nothing on screen,what do i do?
For about $500-$600 repair bill this can be fixed. Do yourself a favor and just replace it, new falt screens are very cheap.
Jan 19, 2012 | Philips Televison & Video
My screen has vertical lines that I can't clear
What is happening to your laptop is the power line connecting a few rows of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Feb 09, 2011 | Philips PET710 Portable DVD Player
Three coloured lines appered on the screen - no picture
If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
easyab
Apr 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Nov 09, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips Ambilight
The correct remote has an ambilight button to toggle ambilight on and off
May 27, 2008 | Philips Televison & Video
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
Ekse
