Question about Frigidaire GLTR1670A Front Load Washer
Dark brown stains
Lately eveytime I do laundry, there is a dark brown stain that comes out on the cloths. Any ideas?? It doesn't feel oily but is that what it could be an where is it coming from??
The rear tub bearing is shot and will have to be replaced you have to replace the whole rear tub. the brown marks are coming from the spider shaft assembly its rusted out you will have to replace the whole stainless steel tub.
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
Posted on Jul 09, 2008
    Novelist:
  • 161 Answers
Try running a cycle on hot with 1/2 cup dishwasher detergent (powdered) in it. Stop it before it pumps it out and restart again, Do this a few times to get a long scrub action. I don't think its oil as a front load machine doesn't have a transmission. If you think this is a rust stain use a rust remover type product instead of dishwasher detergent.
Posted on Jul 03, 2008
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Brown stains on clothes after taking out of drier (removable on hot wash)
Could be rust, is your laundry kinda damp?
Has someone dried a pair if brown or black shoes?
Check the conditions inside the drum.
Use a solvent to remove any dark marks.
Sand away any rust and paint over with high temp paint.
Sep 16, 2011 | Dryers
I have AWM 270-3062 Speed Queen top loader washing m/c. It is approx 15 years old and has never been serviced. Lately dark stains have been visible on the clothes after each wash. The stains come out with...
Stains are one of those things that no two problems are every the same cause. Generally, if it an oily stain then you take a look at something like the transmission. If it is a rubber type of stain the the rubber washer sealing the shaft. Or if it is rusty colored then metal metal somewhere in the wash tub that is rusting.
Sorry, wish there was somehow to tell you where exactly to look, but there just isn't.
Jul 25, 2011 | Washing Machines
Leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
May 09, 2010 | Washing Machines
Dark greasy stains after washing
When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail.
The seal wont be difficult to replace,but to get access to it you have to
basically disassemble the whole machine. The hardest part was pulling the agitator off the shaft - I
use a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way - perhaps yours
will be easier than mine was.
Apr 18, 2010 | LG 4.0 Cu. Ft. 7-Cycle Extra-Large...
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Frigidaire GLTR1670A Front Load Washer Logo
374 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
