Question about GPS
Count get no safety cameras on route66 maxi - GPS
Have a nokia 6110 nav and i downloaded safty cams for a price , it looks like all i got was cams in the city and not country or hwys is this the normal or should i have got more for my money. if any one could help im jashcrof@bigpond.net.au. thanks
Posted on Aug 29, 2008
  • 37 Answers
Cannot be fixed. the satellite must not be aware of them cameras.
Posted on Jun 08, 2008
Can you replace the safety harness on maxi-cosi pearl car seat?
Hi Stuart
The carseat harness can be replaced, but due to the safety implications of it being incorrectly fitted we cannot supply the harness as a spare part for you to fit yourself. The seat will need to come in for our engineers to provide replacement of the harness.
Jan 07, 2014 | Maxi-Cosi Baby Gear
Need new straps for maxi cosi tobi
Hi Mandy
Due to the safety implications of a carseat harness being incorrectly fitted we are unable to supply a harness to you as a spare part item.
To replace the harness the carseat would need to come in for our engineers to provide replacement and safety checks to ensure product is working as per specification. 1924a6a3-e420-4f10-b6df-f9a1deebe867.jpg
Apr 05, 2013 | Maxi-Cosi Priori
Can dreami carry cot fit mura 3?
The combination has not been tested or been given the required safety certificates so we must advise that you do NOT use a Quinny Dreami on a Maxi Cosi Mura 3 chassis.
The Maxi Cosi Mura carrycot or 2013 Maxi Cosi Folding Carrycot ONLY should be used on the Mura for guaranteed safe combination.
The use of a Dreami on the Mura chassis has not been approved and we cannot accept liability for any malfunction of the product combination.
Mar 15, 2013 | Maxi-Cosi Mura 3 Pushchair
Does maxi cosi carrier fit to safety 1st stroller
Hi
No a Maxi Cosi carseat does not fit with the Safety 1st range.
Depending on which Safety 1st stroller you have it may be possible to add a Safety 1st carseat.
Feb 05, 2013 | Safety 1st 01668 Two Ways Tandem - Sahara...
Can I use the Maxi cosi adapter for my quinny buzz seat?
We do not advise doing so. The Quinny Buzz seat unit should only be used with a Quinny Buzz chassis and likewise the Maxi Cosi Foray seat unit should only be used with a Maxi Cosi Foray chassis. A combination of the two has not been tested or approved for safety standards and we cannot guarantee the safety of using such a combination.
Dec 13, 2012 | Quinny Buzz Three Wheel Stroller
I have a 1988 Yamaha XV250 Route66 it dies when put into gear
Hi, Anonymous and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re dies when put in gear Road Star Forum Yamaha Road Star
http://www.r1-forum.com/forums/102-00-01-r1-mechanical-help/261364-bike-just-dies-when-i-put-gear-plz-help.html
Yamaha XV250G Supplementary Service Manual
OEM parts for Yamaha
Yamaha XV250L Owner Manual
Jul 27, 2012 | 1989 Yamaha Xv 250 Virago S
Can I get replacement straps for the maxi cosi cabriofix?
Your Maxi Cosi CabrioFix can be fitted with new straps.
Since this is directly affecting the safety of the seat the procedure is only available from a Maxi Cosi service center.Please visit a Maxi Cosi dealer to have your seat sent to a service center.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 01, 2011 | Maxi-Cosi Cabrio Red Flame Reflection...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to install the maxi-cosi Rodi XR car seat. I
Go to this website http://www.nhtsa.dot.gov/CPS/CPSFitting/index.cfm and put in your zip code, it will tell you where the car seat safety inspectors are and they can help you install it properly.
Mar 29, 2010 | Maxi-Cosi Maxi Cosi Rodi XR 'Phantom'...
Hard reset on Route66 mini
Try updating your Route66 with the latest edition of the PND software from the R66 support website -http://www.66.com/support/index.php?cid=UK&opt=updates - This will reset the sat nav to how it was when it left the factory but you will loose your favourites and history in the process. See the website for more details.
Jan 06, 2009 | Route 66 MINI Handheld GPS Receiver
GPS Logo
110 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
