Question about Western Digital Computers & Internet
My Western Digital Hard Disk is Getting Heated And Also Sometime Creating Noise.....But by far One Most Complicated Problem..My Hard Disk Is Not Detected By My System When Tried Several Times.. My Hard Drive Model Is WD 200 20 gb
    Brigadier General:
  • 10,406 Answers
> is getting heated
Normal for any spinning device.
> sometime creating noise
Normal when the R/W mechanism moves (like the arm on a DJ's turntable) to read from "random" locations on the disk-drive. In general, "defragmenting" a disk-drive tends to reduce the noise, because the R/W mechanism moves less distance.
> not detected ... when tried several times ... 20 GB
Any 20 GB disk-drive is "out-of-warranty" -- like a bald car-tire, it should have been replaced before it totally "blew".
Does it actually get detected, after a few attempts? If so, then "backup" your files (write to CD/DVD recordable media, or write to USB memory-stick) before it totally "dies". Then, buy a new disk-drive, install Windows onto it, and then reconnect the "old" disk-drive as a "slave" disk-drive.
Copy all your files from the "old" disk to the "new" disk.
Posted on Oct 24, 2010
SOURCE:
When pc boots My wdc hard disk shows sec master hard disk S.M.A.R.T status bad backup and replace
your hard disk getting damage so take back up fast and replace hard disk with new hard disk smart test when hard disk want when hard disk surface going some hardware problem
May 22, 2012 | Western Digital Computers & Internet
Hii, When I plugg in my western Digital Hard disk it sometime get detectable and sometimes not and it is sounding like Tic tic. Could you help me how to resolve this problem.
hi
This is because the hard disk is not getting the sufficient power from the USB port. Try connecting your hard dik on other PC and repeat he steps three four times and see the behaviour.
Besides your hard disk is fine !!!
Regards
Vipin Kakkar
Jan 30, 2011 | Western Digital (WD3200JS) 320 GB Hard...
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows...
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Oct 24, 2010 | Western Digital Passport WDXML800UE...
Windows cannot recognize my western digital external hard drive. I am getting an error msg: "Windows cannot recognize this device". I need to retrieve my files! Help!
The device has suffered a major failure. If you're lucky it's in the electronics of the case so take it apart, extract the hard disk inside, put it in another external case (or directly inside a desktop) and access it this way. If even then the disk isn't recognized then the hard disk itself has died and all the data on it is lost.
Aug 23, 2010 | Western Digital External USB 2.0 80 GB...
Its not getting recognized...though it used it before
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Best regards
Jan 08, 2010 | Western Digital Passport 320GB External...
Hard disk not detected sometimes
I can think of 3 possible causes to your problem:
1. Faulty cable - try replacing the cable by borrowing a working cable from a friend. If this solves the problem then you need to buy a new cable
2. Lack of power - some USB drives especially those for high capacity drives require extra power aside from that provided by USB. If you do not have a separate power leading to your drive, check if there is a separate power slot and run a cable from it to your outlet/USB slot. Just make sure that the voltage levels are correct.
3. USB Slot - some laptops' USB slots do not produce power enough to drive a hard disk. Other devices may work (e.g. keyboards, mouse) but not hard drives. Try to use another slot in your laptop. If this works, remember to use the same slot next time.
Hope this helps.
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Western Digital External USB 2.0 80 GB...
My western digital hard disk wont work how to fix it?
There are many possiblities for your hard drive.
You can use the following that software to repair your hard disk.
  1. Western Digital DM (Disk Manager)
  2. Spin Rite
  3. Hard Disk Regenerator 1.1 or later version
If you professional or understand computer better, you can repair your hard disk to use one of above mentioned software.
Good Luck
Nov 21, 2009 | Western Digital Computers & Internet
What to do if the disk is not detected?
Hi ctieprabanda,
Check your bios, to see if it detects it there? If not switch the sata cables and try. If that doesn't work , then you have a dead drive.
Good Luck,
Mark
Nov 09, 2009 | Western Digital Caviar SE WD1600JS...
Cannot Read External Western Digital Mybook 500GB Drive
I have ".Window 7." Sometime I see a icon and it shows the drive size and can't read and my work. Yes, I do save my work on my hard drive, but I also want to save it on my external drive. . I even reboot.
Jan 13, 2009 | Western Digital 500GB My Book World...
Western Digital My Book Pro - Replace Disks
Same problem. This from WD Answer ID 1664:
Important: The user serviceable enclosure will only work with replacement hard drives from Western Digital. Inserting a non-Western Digital hard drive into the enclosure could cause damage or data loss.
So Hitachi drives will not work at all. After talking to tech support, it seems you have to have them send you a replacement disk in order for it to work.
I'm looking for a way around this since I want to upgrade my dual 500 G drives with dual 1 TB drives also. Maybe they throw something onto the boot sector that tells the MyBook controller what to do, who knows? The search goes on.
db
Oct 24, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
123 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
