Question about LG Televison & Video
When i turn my tv on it flickers badly the problem seems to get better after a couple of hours as if the tv is warming up
  • 11,361 Answers
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps
Posted on Oct 27, 2010
SOURCE:
Flickering screen
hi. you problem maybe in power supply unit. couple capacitors bad between power supply to inverter board. good luck!
Sep 22, 2012 | Philips BDL6551V 65 LCD flat panel display...
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
When turned on, the screen has waves in it across the top and flickers. It is unreadable. When the TV warms up it seems to be better but is starting to flicker or flash all the time now.
Your Toshiba TV has hyperboard inside and there are few electrolytic capacitors (may be 10) that need to be replaced.
If you are comfortable with soldering parts in PCB then go ahead or ask help to any friend that knows electronics stuff repair.
Let me know further query.
Thanks.
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
When turned on it Flickers
Mine started out like that, now flickers about an hour before it comes on. I don't turn it off anymore, it'll burn out one of these days and I'll get a better TV.
Jan 01, 2009 | Audiovox FPE3206 32 in. LCD Television
Color flickers on and off
I went to the Sony support page for your model.(link below)http://esupport.sony.com/US/perl/model-home.pl?mdl=KP61V85&LOC=3
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
T.V. would take about an hour to warm up.
I have answer serveral times about this ck 3 capacitors on deflection board.cp150- cp111- cp114
Oct 02, 2008 | RCA D52W19 52" Rear Projection Television
TV problems?
you could have a couple of problems here
sounds like your tuner is bad but it may be repairable
useually when you first turn your tv on its cold then heats up and more then likley solder joints start to open uafter warm up then if you shut your tv off for a few sec. turn on it may be okay till solder joint get hot then open up tou need your tv reaired or buy new one
Feb 17, 2008 | Televison & Video
Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Jan 24, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Soyo 32" LCD flat panel
Better to send it back before the warranty expires, the set has issues
Oct 21, 2006 | Soyo DYLT032D 32 in. LCD Television
Televison & Video Logo
54 people viewed this question
Ekse
