Question about IBM ThinkPad T40 2373 Notebook
I need the bios password for IBM think bad t4o with out short circuit
  • 393 Answers
There is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html Thanks
Posted on Nov 11, 2010
SOURCE:
I CANT'T PASS BIOS PASSWORD ON IBM T43P
There is no way to reset the bios password. IBM have not got jumpers to short in this model and recommend a new motherboard.
Feb 01, 2014 | IBM ThinkPad Computers & Internet
Ibm think pad bios locked
Short pins on the bios chip. I have done this on T42's. I assume it will work on T30's as well. You'll have to search the internet for which pins to short (usually pins 5 & 6 or pins 7 & 8), but you short the pins together and turn the machine on. Be careful! Do it at your own risk. Once you are into the BIOS, you cancel the password settings and save.
Jan 24, 2014 | IBM ThinkPad T30 2366 Notebook
Ibm t4o bios password i have forgoten how can i rest set this?
In order to reset passwords normally on any computer you will have to either remove the battery or reset the CMOS jumper. Also I recommend that you get the default passwords for you brand and try those first they sometimes work when accessing passwords.
The supervisor (SVP) password is stored in a chip called ATMEL 24RF08.It can not be reset by disconnecting the BIOS battery or shorting any jumper. It has to be read in order to decipherer the password. For this we need some kind of hardware so read on...by clicking this link. Click Me If that is the case and I did research this to see if the above method would work and that is what I found out. So it may move you to look at that web site page above to make sure that you have the right information. I advise that you take this to someone that knows what they are doing also there is probably a simpler way to do this possibly. Every BIOS is different yours may seem to be the case for more research than I'm familiarizer with.
Always try to pick passwords that are easy to remember and use few of them I have two usernames and passwords I use regularly as well as I will never forget them. If you are using passwords and usernames a lot for banking and private information it is good to change those often but remember what they are write them down and put them somewhere where you can find them. There is also password retrieval software available for use as well some free and others paid.
If you can access the battery you can find that underneath the laptop you may have to remove the case covers if it is pop out kind just remove it then place it back in the carrier. This should reset the BIOS to default settings. Thanks for the great question? I even learned something here! John
Jan 21, 2011 | IBM ThinkPad T40 2373 Notebook
Need ibm thinkpad t40 2373 bios password and bios circuit name
FOR IBM/LENOVO PASSWORD
Hello sir read these instruction. Solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. you need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..you need to made serial port or printer port and there is software for it ...
Dec 02, 2010 | IBM ThinkPad T40 2373 Notebook
I forgot the password
Hard Disk Password
The hard-disk password (HDP) protects the data on your removable hard disk drive from being accessed by unauthorized persons.
Supervisor Password
The supervisor password protects the system information in Easy-Setup from being changed by unauthorized persons.
How to Reset an IBM ThinkPad Power On Password using Software
If you can boot the IBM ThinkPad, KeyMaker will recover the messagebox_info.png BIOS password.
How to Reset an IBM ThinkPad Power On Password Using Hardware
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Power on the computer by pressing and holding F1.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click on the Password messagebox_info.png icon.
  4. Click on the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click on Exit; then click on Restart.
Oct 26, 2010 | IBM ThinkPad X21 2662 Notebook
Bios password IBM tnink pad X30 missing...
  3. Click on the Password icon.
Oct 19, 2009 | IBM ThinkPad X30 2672 Notebook
Ibm x31 password problem
Visit: http://www.ja.axxs.net/unlock/
Jun 19, 2009 | IBM ThinkPad X31 2672 Notebook
Im forget mein passport
Please rate my response.
Feb 17, 2009 | IBM ThinkPad T20 Notebook
Bios password
ibm think pad r40 bios password cracker
Oct 11, 2007 | IBM ThinkPad A21m 2628 Notebook
Startup Password IBM Thinkpad T40
How to Reset an IBM ThinkPad Power On Password Using Hardware If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware. If only the power-on password is set, do the following to remove the power-on password. Power off the computer Remove the DIMM cover on the bottom side of the computer. Short-circuit the two password pads or put a jumper on the contacts to short the circuit. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed. Reinstall the DIMM cover. If both the power-on password and the supervisor password are set, do the following to remove the passwords: Power on the computer by pressing and holding F1. Enter the supervisor password. The Easy-Setup menu appears. Click on the Password icon. Click on the Power on icon. Enter the supervisor password and press the Space bar. Press Enter twice. Click on Exit; then click on Restart.
Aug 25, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
