Question about Electrolux Gas Hedge Trimmer
How do I adjust the Carburettor on my Electrolux HG 18 Gas Hedge Trimmer please?
5 Suggested Answers
SOURCE:
wadembly
  • 513 Answers
SOURCE: I can't adjust the carburettor on a Homelite Hedge Trimmer
it shouldn't be all that special it'seither a small flat tip screw driver or its usually a torques screw either one should be avalible at any hardware store or toolstore
Posted on Jun 08, 2009
  • 110 Answers
SOURCE: echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Posted on Nov 01, 2009
  • 29 Answers
SOURCE: Blades won't operate....motor is running - 18" gas hedge trimmer
centrifical clutch oily or slipping.
Posted on May 01, 2010
philwalker78
  • 608 Answers
SOURCE: What is the spark plug gap on a Electrolux/Partner
Hi, the gap should be .8mm or 30 thou. Hope this helps, regards Phil.
Posted on May 31, 2011
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
What is the spark plug gap on a Electrolux/Partner HG 550 petrol (Gasoline) hedge trimmer
May 31, 2011 | Electrolux Garden
I have a Ryobi HT26.In the back of the primer under before the gas tank is a choke lever and throttle lever.My choke lever is connected to nothing in the back or front of mygas diaphram.Does'nt it soppose...
If you remove the air filter you should see the choke butterfly valve on the air intake to the carburettor.
The choke lever should be connected to the axle of this valve on the outside of the carburettor.
Apr 13, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
Does anyone know the factory mixture setting screws for electrolux hedge trimmer
Carefully Bottom each screw and turn out 1 to 1 1/2 turns. This should get you started. Adjust low and high speed screws till it idles and does not hesitate on high
Oct 21, 2009 | Electrolux Gas Hedge Trimmer
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Jun 08, 2009 | Garden
My hedge trimmer keeps switching off
It sounds like you may have a loose wire some where that is grounding out. You might want to check all wire connections to make sure that they are tight and also check for any bare spots in the wires were they could be touching metal and grounding its self out.
Jan 06, 2009 | Electrolux Gas Hedge Trimmer
22" excalibur hedge trimmer has no spark and will not start
remove plug and ground and see if you have spark at electrode.
Sometimes will not fire under compression.
Check that kill switch is not shorted, just remove the wire going to ground and try again.
If not probably bad coil.
Joe
Dec 02, 2008 | Electrolux Gas Hedge Trimmer
Electrolux Gas Hedge Trimmer Logo
102 people viewed this question
Top Electrolux Garden Experts
roeb
john h
Marvin
Marvin
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
