Got a second hand micromark mm9088 dehumidifier with no instruction manual, plugged it in and turned it on to max, flicked the switch, the light came on but the fan is not going round and there isn't any sound coming from it at all
SOURCE:
  • 1462 Answers
SOURCE: no instructions
only two fan speed - fast or slows. use fast humidity - cuts out appliance when required humidity is reached. set it about half way note that is f bucket if full, then a float switch will cut out the appliance
Posted on May 22, 2007
  • 5 Answers
SOURCE: fan does not come on
I've seen abunch of these. The fan motor has a fuse wound into the windings. It cannot be replaced you need a new fan motor. The motors seem to run hot normally, leading to a short lifespan.
 I suggest buying a better brand unit.
Posted on Oct 26, 2007
yeroc
  • 397 Answers
SOURCE: Ceiling fan light works with wall switch, but comes on dim when I pull the chain for the fan
is the fan working correctly, if it is not it could be a bad armature or field
Posted on Jan 20, 2008
SOURCE: empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
Posted on May 31, 2009
  • 44 Answers
SOURCE: i have a 42 in philips tv that wont turn on green light comes on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
My dehumidifier is only about a year old and the bucket full light keeps blinking. i turn it on, it sounds like its going to kick on but shuts off a second later.
It sounds like the switch under the bucket is stuck. Remove the bucket and there should be some kind of switch where the bucket rests against. Make sure the switch works freely if not spray a little contack cleaner on it and work the switch by hand until it frees up.
Mar 11, 2011 | Goldstar DH504EL Dehumidifier
I have an LG LHD65EBL dehumidifier. When I checked on it today the unit was not running and the display read "CH 01". I tried cleaning the filter, cleaning the front of the coils, and resetting the unit by...
Hi
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
Aug 15, 2010 | LG LHD65EBL Dehumidifier
The red indicator light just flashes when i turn the unit on. Whats wrong?
Good luck.
Aug 12, 2010 | Kenmore 54351 Dehumidifier
BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Aug 03, 2010 | Samsung SRS20DTD Side by Side Refrigerator
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried...
Post comments  for more help or information .........
Good Luck!!
Thanks
Dec 22, 2009 | Holmes Products Cool Mist HM3500...
What are the settings (humidity)from 40 upwards on my micromark ? . Is the lower setting to take out most moisture ? Thank You
40 is 40% humidity in room - that's really dry.
For moist area you usually want 50 or 60%.
Dehumidifiers are for damp areas. If temp ouside is below freezing, inside house is probably already too low.
Dec 01, 2009 | Dehumidifiers
My DeLonghi DEM10 wont power on any more - like fuse gone
Sep 03, 2009 | DeLonghi Dehumidifiers
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
No instructions
May 21, 2007 | Ebac HD880 Dehumidifier
Open Questions:
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
