Question about Amazon Kindle Wireless Reading Device
My Kindle is turned on ( i cant tell as my lighted cover light comes on) however the screen is still blank. What can i do to fix this? Thanks!!
    New Friend:
  • 51 Answers
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Posted on Mar 01, 2011
SOURCE:
Touch feature for my Kindle Fire HD is not working. I may have accidentally changed the setting? How do I fix it?
Hello Friend...
Many issues with your Kindle Touch, such as a frozen screen or issues with downloading content, can be solved by restarting your device.
1.Press and hold the Power button for a full 40 seconds.
After the first 6 to 8 seconds, the screen will go blank, which is normal. Continue holding the Power button.
2.After the 40 seconds, release the Power button.
The charge indicator light will turn on after a few seconds.
For any query or support, visit us: Kindle Fire Support
Oct 10, 2016 | Amazon Kindle Fire HD
My Kindle screen is blank. When I try to turn it on, the green light goes on, then off, and the screen stays blank.
The best thing to do is contact amazon.com, place cursor on Your Account, click your account at top of list. on the right you should see Kindle Help Home; click it and it will bring up info about your kindle. On the far left in a box is CONTACT US. Fill out the form and choose how they should contact you. If you leave your phone they will call back and talk you through how to fix the problem. They may ask the return so they can work on it. Amazon help is always free. You only pay if you have to return it.
Feb 01, 2016 | Amazon Kindle
The charging light will come on, but when I turn on the kindle the green light comes on for a second then goes off and the screen stays blank
the battery has died . take it to a computer shop and see if they can replace the internal battery
Dec 05, 2015 | Tablets & eReaders
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
I still can't get my Kindle to turn on even after holding the slide switch on for 7seconds. The green light flashed x 3 and went off but my screen didn't go blank. I've held the slide switch on for 15...
First call amazon customer support! They are really good at helping you get your kindle back up and running.
A couple questions to ask yourself Is the kindle fully charged? There might only be enough power for the green LED and not the actual kindle!
If this is your last resort:
I have never done this, and it would certainly void your warrant but I am told that there is a reset button underneath the cover of the kindle...
Feb 24, 2011 | Amazon Kindle 3G
My amazon kindle is unreponstive.how can I fix it, has blank screen will not let me connect to internet
Feb 23, 2011 | Amazon Kindle Wireless Reading Device
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
Kindle 3g screen is blank can get it back on
Jan 17, 2011 | Amazon Kindle Wireless Reading Device
My kindle went to sleep and now won't turn on.
Some older Kindle covers (original Amazon leather covers, non-lighted versions only) interfere with electrical contacts inside the Kindle via the hinge clamps that connect the cover to the Kindle. If you have such a cover, remove it first. If not, just continue with the next steps.
Make sure your Kindle is fully charged before you continue.
  • Note, the Kindle merely goes to a suspend mode if you give the on/off switch a short nudge only, it does not really switch off.
  • Slide and hold the on / off switch until after the power light flashes three times. This takes about five seconds.
  • If the device boots now, wait until its finished and you can use it again.
  • If the screen just goes blank, do the slide-and-hold again.
  • If the Kindle still does not boot, there is a defect that cannot be cured by a simple reset. You will need to contact Kindle support for warranty repair.
Check if your Kindle works normally again. If you removed a cover before, re-attach the cover now. Observe the Kindle's behavior, if the same thing happens again with cover attached, contact Kindle support. The reported Amazon policy in such cases is to refund your cover and add a voucher for the price difference to the lighted version, so essentially your non-lighted cover gets exchanged for a lighted one. Not a bad deal.
Jan 14, 2011 | Amazon Kindle 3G
Amazon Kindle Wireless Reading Device Logo
220 people viewed this question
Top Amazon Tablets & eReaders Experts
Norman Worley
Miguel Luiz Martins
Poul Brinchs Larsen
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
