Question about Krone Computers & Internet
Hi,I have a Krone AMT 323CRI mower conditioner. Mowing our crops today, we had problems with the crop jamming between the rollers. We opened up the space, tried driving faster and then slower, but the crop continued to jam. Any ideas???
SOURCE:
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
  • 39 Answers
SOURCE: Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Posted on Mar 03, 2009
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
SOURCE: The print shop is not cropping correctly. Once I
You have to choose area effects tab first, click on the area (aprox) where you are going to crop, then choose crop and orientation tab and do your croping. I don't know why it works like this, but this has solved the problem for me.
Posted on Mar 25, 2010
PS CS6 How to drag a layer into another PSD file at-size?
>Open "My Computer" from your desktop. Double-click your hard drive.
>Open "Documents and Settings."
>Open the folder labeled with your user name.
>Open "Local Settings" followed by "Temp."
>Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
>Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
>Select "Save As" from the "File" menu when you find the temp file you want. This will make the file permanent.
also use Photoshop Restore Toolbox
http://www.photoshop.restoretools.com/
Apr 25, 2015 | Adobe Photoshop 7.0 for PC
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
How to make file size of photos small to send by email?
I'll give you a trick! it has a large file size because of pixels, so you need to minimize it.
Open the file with mspaint and crop"
1. right click the file that you want to minimize file size, then choose " open with " then there's a option of program, choose the mspaint .
2. then once the picture was already open with mspaint, goto toolbox and choose the Crop tool..
3. Crop the picture..then open a new mspaint, then paste the cropped picture into it, then save afterwards..
4. then its done.
Good luck & please rate..
Mar 21, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Want to crop my profile picture
Can't you just crop it on your pc, THEN upload it again, overwriting the current one?
Apr 08, 2010 | Facebook Social Network
Opening saved Gimp file
Hi Amber.
If I read rhe above correctly, you have got your last saved image back. You had only marked out areas to crop, you hadn't cropped them.
It follows then that you hadn't made any changes to the file.
Sep 13, 2009 | GIMP GNU Image Manipulation Program
The print shop is not cropping correctly. Once I have the image I want to crop ready and click on applty crop the image crops another area such as the feet of a person.
Jul 12, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Scanner crops documents
Go to the official Canon website: www.usa.canon.com and redownload driver and MP Navigator. MP Navigator lets you choose the size of the scan you want. I was having the same problem and just fixed it today.
Jan 27, 2009 | Canon Pixma MP450 All-In-One InkJet...
Indesign Crop Mark and nudge
To crop or straighten images in Camera Raw
In the Camera Raw dialog box, select the Crop tool or Straighten tool .
(Optional) If you want the crop area constrained to specific proportions, click the Crop tool icon and choose a proportion from the pop‑up menu. Choosing Custom opens the Custom Crop dialog box, where you can specify the proportions or the dimensions of the crop. Click OK.
Do one of the following:
To crop the image, drag the Crop tool over the image.
To straighten the image, drag the Straighten tool in the preview image to establish what’s horizontal or vertical.
(Optional) To adjust the crop area, do one of the following:
To scale or rotate the crop area, drag just outside the bounding box handles.
To move the crop area, click in the bounding box and drag.
If you selected several images in the Camera Raw dialog box, they are all cropped to the same size, with the crop applied in the same position.
Note: To cancel the crop operation, press Esc with the Crop tool selected or click the Crop tool and choose Clear Crop from the pop‑up menu. To cancel the crop and close the Camera Raw dialog box without processing the camera raw image file, click the Cancel button or deselect the Crop tool and press Esc.
Click Open, Done, or Save to apply the crop and process the camera raw image file.
Oct 20, 2007 | Adobe InDesign CS2 for PC
Computers & Internet Logo
74 people viewed this question
Top Krone Computers & Internet Experts
Ekse
Alun Cox
Are you a Krone Computer and Internet Expert? Answer questions, earn points and help others
