Question about Video Game Consoles & Games
It says "system date error! please check NDS system date"
  • Andrea Ollier Oct 24, 2010
    We had to take it a year back. but it is now working thanyou very much!!!
  • 10,515 Answers
A method to fix this is as follows :-
  • Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
  • Done
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 24, 2010
  • taran_2005
    taran_2005 Oct 24, 2010
    Thanks for your response!!
    Glad that it worked.
    Hope i helped you.
    PS - Do accept the solution,if 100% satisfied from my response!!
SOURCE:
System error please check nds system date
Remove all game cards from your NDS, turn it ON then touch the small NDS button and set the date. If you still get the same error message, set the YEAR about 2 years earlier (2009).
Aug 06, 2011 | Nintendo DS Lite Console
System date error please check nds system date.. i have been try and update etc but there said errow now.. i not know what to do next
Hey, it's a common issue that's newly come up for <a href="http://www.dscardworld.com">R4i SDHC</a> the new update will fix it, or you can roll back the date on your DS.
May 19, 2010 | Nintendo DSi Black Console
System date error! please check nds system date.
Sounds the new error that's come up for <a href="http://www.dscardworld.com">R4i SDHC</a> . The new update should fix it or you can rollback your date on your DS.
May 19, 2010 | Nintendo DS Lite Console
System date error! please check NDS system date
It's a bug issue in the firmware of the R4 cards. Won't work after 14 april 2010 unless you update the firmware of the R4 card.
For the time being you can set back the date before 14 april 2010 and it wil work directly.
gr
Apr 19, 2010 | Nintendo DS Lite Console
System date error! Please check NDS system data. This has come up on screen, could you give any advice please
Hi ya
remove your R4 card. Go to the system setting and turn your date on the dsi back by a year!!
Put your R41 back in and it should work.
happened to my sons and the only way it would work was to turn the date back.
Apr 18, 2010 | Nintendo DSi Black Console
DSi system date error please check NDS system data
Remove the cardset the date to 01/012009 on your consol. Put the card back in and it should work
Apr 17, 2010 | Nintendo DSi White Console
R4 card being working fine, system date error now
Goto date settings and change it to the 13/04/2010
Apr 14, 2010 | Nintendo DS Lite Console
Dsi system date error
Tried this myself - you could actually set it back to 2009, so just change the year, not the date.
System date error! please check NDS System date on R41 card
I had the same problem. I fixed it correcting system date *before* the real date ( 1 day before in my case). It worked!!
Oct 26, 2009 | Nintendo DS Lite Console
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
