Question about Aiwa Audio Players & Recorders
Aiwa 3-cd changer # CX-NAJ20U - 8ANF9-061 My CD'S are skipping even NEW ones. I have 2 different CD Player cleaners that I use but CD's still skip. Some how the CD'S come out of player scratched, it's like the lazer is loose or damaged. This is a FINE Stereo system if only I could use CD player. I purchased this Unit 8/2000 but really haven't used this very much. PLEASE HELP, I don't wanna throw this away like every thing else made in CHINA. I've been shopping for stereo systems and nothing available has the Quality andf features this has. HELP ME FIX IT Michael Young
  • 10,515 Answers
Is this an issue with a particular brand or random?
If it is random, this is an internal problem with player. As the CD's come out of player with scratch, it could be a problem with drive or lens problem. You are correct in thinking that repair would not help as the cost of repair is quite high as compared to the cost of the product.However, you have to understand that this is a consumer market, and all manufacturer's ( most of them excluding Bose ) made their product in such a way that once there is an internal problem, the best option would be replacement.
You could try to fix it, however you have only limited options unless you wanted to open and fix it yourself.
1. Unplug the unit for few minutes, say 15 minutes and then turn it ON. This would reset the machine. Then, give it one more shot with a new CD ( make sure that it should not be scratched ).
2. You could use a lens cleaner CD to clean the lens.If your player is skipping any discs at all though, then try purchasing a can of compressed air (available at Staples, or Wal-Mart). Open the CD drawer, or remove the cover of the player by removing the screws on the sides and rear of the unit. Then spray the can approximately 10" from the lens to blow any dust off of it.If it still doesn't work, you can opt to clean the lens eye itself, by using isopropyl alcohol, and a lint-free cloth to gently wipe the "eye". Then use a dry spot on the cloth to buff the eye clean. If the CD player is still not reading all the discs, then the lens or transport mechanism is faulty and would need to be replaced.
This could be a DIY ( do it yourself ), however not an ideal option as it would be quite expensive to replace the mechanism and still there is no guarantee that it would work for many years.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 24, 2010
SOURCE:
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
Won't play cd all I get is troc read
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Take care.
Apr 13, 2011 | Emerson MS3100 3-Disc CD Changer
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Aiwa 3CD changer,Model no.CX-NK550HR, CD Player not working.CD Board is required to be renewed.Where can I get original CD board of above mentioned model
some one help me...my aiwa vcd component model no. CX-NK550HR suddenly dont open or power up... i think it have a problem in its transformer...what do u think???kindly send me a response on my problem pls.....
ym:jhongojar
email add; [email protected]
Nov 12, 2009 | Aiwa Audio Players & Recorders
The clock on my shelf system cx-naj20u went to 24 hour mode. How
To switch to the 24-hour standard
Press CLOCK while pressing SHIFT on the remote control and
then press S within 4 seconds.
Repeat the same procedure to restore the 12-hour standard.
Apr 04, 2009 | Aiwa NSX-AJ20 CD Shelf System
Car cd player skips on bumps
This can happen for several different reasons.
1. The dampers (oil filled shock absorbers) are leaking and need to be replaced. You can check this by taking the unit out and opening it up and then remove the CD deck. In each corner of the CD deck you will see a small rubber looking device that the internal mech floats on when a disc is engaged. It is attached to the internal mech by only a small metal peg. Check each corner for these. Make sure they are not leaking anything. It is usually a white looking substance that feels like grease. Ant time even one of them go bad or get popped out of place, it will skip on every bump.
2. Try cleaning the lens. Sometimes a dirty lens will make the CD player skip much easier than it is supposed skip. You can buy a cleaning disc at most retail outlets that sell CD and DVD players. Run it as directed in the instructions.
3. one or more springs are streched out a little. These mechs have many springs in them and if one is a little streched it will cause skipping. If you find a loose spring, it will need to be replaced.
4. Weak laser output. A weak laser will also cause a unit to skip. If this is the case the laser pick up will need to be replaced. There is no fix for a weak laser other than replacing it.
5. Spindle motor problems. A spindle motor with even a tiny bit of oxidation in the windings can cause skipping when you hit a bump.
There are also a few other things that can cause this same issue. It is not an easy thing to fix without some training on this type of equipment.
Is this an "Aiwa"  or is this a factory unit that cmae with the car when it was brand new. I don't think that Aiwa is an OEM radio, but I could be wrong. I fix aftermarket radios only.  So I am not real familiar with all the OEM models.
If this is an aftermarket Aiwa radio, you should take it to a service center to get an estimate. If it is an OEM radio, it is most likely going to be very expensive to fix and a good aftermarket radio would really serve you better.
I am sorry if this is not the answer you were hoping to get, but it is the truth so I hope you will not punish the messanger for bringing bad news.
Anything less than a "helpful" rating is a very bad rating meaning that you got no help or that the help was not related to the problem. I spent a lot of time putting this information out here for you for free, so I only ask that I get a decent rating for my trouble.
If you require any more help feel free to post another comment on this thread with any questions you may have. I will be happy to answer them for you.
Dave
Jan 22, 2009 | Aiwa CDC-X227 CD Player
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
My 02 Maxima's CD player freezes and skips.
my cd changer skips alot i dunno wht to do i cleaned it it woorks fine while sitting still but as soon as i drive it skips:(
Nov 21, 2007 | Car Audio & Video
332 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
