Question about SanDisk Sansa m250 MP3 Player
Sansa won't turn on, battery not dead
My sansa won't turn on, but if I plug it into the computer, it connects with the computer. I know the battery isn't dead, and i'm wondering if there are some issues with the wires. I know it gets tossed around quite a bit and it often turned off if I dropped it.
  • Mortal123 Jun 19, 2008
    I have The Same problem Its not turning on no matter
    wat i try
    Im in india so i have no sandisc dealers
    pls help mee
I have the same problem, the mp3 player won't turn on at all except when connected computer. It's not a battery issue as I've tried a few batteries in it.
I tried holding down the power button for 15 seconds (which someone suggested would reboot it) but that didn't change anything.
Posted on Jun 10, 2008
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa mp3 has frozen nothing moves,it is on , how can i dislock it
Hi,the Sansa is a portable media player made by SanDisk. As with all portable media players, there may come a time when your Sansa freezes up for one reason or another. This can be incredibly frustrating. Fortunately, there are a handful of different methods you can use to unfreeze the player.
Instructions
Wait for the battery in the Sansa to die completely. Once the battery is dead, you can plug the Sansa into your computer and download a firmware update for your particular model (see Resources below). You can also remove the battery from the Sansa if you want to speed up the process.
Plug the Sansa back into your computer. If the computer recognizes the device, the player should begin charging right away. This will unfreeze your Sansa.
Hold the power button down for roughly 10-20 seconds. The Sansa should turn off. Wait a few seconds and then turn the player back on.
Hold down the center button and the menu button at the same time. Do this for up to 30 seconds while watching the display screen.
Hope it helped.
Thanks for using fixya.
Jan 12, 2011 | SanDisk Sansa Clip MP3 Player
I have a sansa connect 4g it does not want to charge it was charging (blinking blue light on power button) and then it took 2 hours until it breifley turned on and shut off. is the battery dead-if so can...
The battery could be dead and can be replaced if you have another player as batteries aren't sold separately. But first try the Sansa Recovery tool found on the following website and let me know how that goes. http://www.sansacommunity.com/article/11050/Sansa-Connect-Recovery-Tool-Procedures/
Benjamin
Nov 05, 2010 | SanDisk Sansa Connect MP3 Player
Sansa clip will not turn on.
hey dude something is lose inside it has no connection to the battery but the actual port that you plug your pc in does ... myn is also like that and iv had it for a year now,,,,
Jul 09, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa plugged into Ipod music player - won't work now
Yep - it's a sad thing. iPod docks have ruined many a good mp3 player. Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa E280 MP3 Player
My SanDisk Sansa 4.0 GB does not power on @ charge.
Make sure that your sansa lock switch is in the unlocked position.
Aug 14, 2008 | SanDisk Sansa e200 MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
228 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
