Question about Sharp 32C-240 32" TV
When the sharp blue screen mix with red colour what component you think is the troble
  • 998 Answers
Check first the location of your tv if their is a magnetic appliances if nothing try to check the demagnitizer if their is a loose solder it is located beside your ac supply inside your tv.
Posted on Oct 24, 2010
SOURCE:
RED COLOUR MIX IN EVERY COLOUR
Provide brand and model number and a photo of what screen looks like.
Dec 03, 2012 | Televison & Video
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
I hve a sansung 48 v monitor. the screen is very much redish
CRTs use 3 "guns" to mix the 3 "primary" colours (RED, BLUE, GREEN). One of the other guns has stopped working, leaving the RED gun as the "dominant" colour.
Spend $30, and buy a pre-owned 15" LCD monitor.
Or, spend $100, and buy a new 17" LCD monitor.
May 26, 2010 | SAMTRON 55V 15" CRT Monitor
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
When I plug in VGA there is a green mask or Hue, over the whole screen... I tried changing the settings but its not controllable with colour settings
I would try a different VGA cable, if you are using a VGA to component cable (VGA on one side and red, blue and green on the other end) you can just have the cables mixed up, make sure red is with red and so on
Aug 18, 2008 | Televison & Video
Colour
it sound like you haveing troble with your red crt...could be crt socket circuit board or actually crt.
Dec 01, 2007 | Akai PT4298HD Rear Projection Television
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Sharp 32C-240 32" TV Logo
75 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
