Question about Garmin nuvi 750 GPS Receiver
Have garmin nuvi 265w forgot security code - Garmin nuvi 750 GPS Receiver
  • Garmin Master
  • 589 Answers
Have you ever had it Registered?
If not you have to before any maps are loaded...... with the unit off connect the GPS to your computer using the USB connector cable...(its the same usb connection a camera uses connecting to a computer)..
Once your computer detects your GPS it will say new hardware found
go to www.MyGarmin.com and Register your unit
Garmin will also detect your model number and let you unlock the maps and firmware
FYI where you set up the GPS will be your SECURITY LOCATION if you ever lose your pin number you would have to travel back to the security location to unlock your unit
Posted on Nov 02, 2010
SOURCE:
How do i reset the pin to a Garmin Nuvi 265W Car GPS Receiver this device that i purchased used?
Unfortunately, you can't reset the PIN. If you know the previous owner's security location, it will automatically unlock at that location and you can then reset the PIN code. Otherwise, you have to send it to Garmin, with an original receipt from an authorized Garmin dealer and they will unlock it for a fee. Other than those two solutions, your unit is now useless. This is a security feature on the Garmin GPS units to prevent units from being used if they are stolen. I would take it back to the person who sold it to you and request a refund.
Dec 20, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Garmin Nuvi 265W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Would you like to back up a copy of your Garmin Nuvi 265W Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Download Garmin Nuvi 265W WebUpdater here.
I forgot my pin code for the nuvi265 I dont know any way to get it to reset.
You can take it back to your security location which you set when you entered the PIN code. It will then automatically unlock and you can change the PIN code to something you will remember.
Dec 12, 2010 | Garmin Nuvi 265W GPS Receiver
I FORGOT MY PIN TO MY JARMAN NUVI 265W HOW DO I RESET IT
Take the unit to the location at which you first set the PIN. This is your Security Location. The unit will unlock and you can reset the PIN.
Sep 20, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Download Nuvi 265W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265 or 265W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 265W GPS Receiver
My nuvi 265W screen keeps flashing the "GARMIN" startup logo...and wont stop
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Apr 05, 2010 | Garmin Nuvi 265W GPS Receiver
I forgot my four degit pin to my garmin nuvi 265 gps
Either bring it to the location where you programmed the code or send it back to garmin2_bing.gif. this is an anti-theft feature.
That is the only way to fix it.
Jan 26, 2010 | Garmin Nuvi 265W GPS Receiver
Nuvi 265w powers on but will not load
I hope that helps.
Sep 21, 2009 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
133 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
