Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
The box keeps searching for channels - Philips Magnavox 50ML8105D 50" HDTV DLP TV
  • Philips Master
  • 1,527 Answers
Hello,silly question is the aerial connected, also if you've got s skybox make sure it's connected i'e the aerial is in the skybox and a lead from the skybox to the tv
regards
shaun
Posted on Oct 24, 2010
6ya staff
SOURCE:
My box keeps saying boot. When I channel search, no channels appear. How do get channels to watch?
Plug the antenna into the ANT IN input of the STB. Forget about the RF IN output of the STB. Plug the 3-way output of the STB into the corresponding 3-way input on the rear panel of your LG TV.
Sep 18, 2016 | LG Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
We have an antenna, digital converter box, and digital tv. Can only get 5 channels. No nbc, abc, cbs. Get the message indicator available for digital broadcasting only
You should be able to use the box remote and select channel search mode. As it searches, you will see it "hit" available channels and store them. When channel search is finished, you should see a picture displayed. if no results, there is something wrong with the antenna, the way it is connected to the box, the way the box is connected to the TV, or the way the TV is connected to the box. You may have to reread the instructions to find what is at fault.
Sep 05, 2015 | Televison & Video
Lost channel 3 to watch tv on uverse
you need cable box on when you search so the tv can find it
Feb 16, 2015 | Westinghouse SK-32H640G 32" LCD HDTV
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
Can't get General Instruments cable box to search
if you have a cable box then you will not need to search for channels. Depending on the cables you are using to connect your TV and cable box, the input channel the TV needs to be on changes. Cycle through your available inputs by using the Input or Video Source button on your remote. Check each one for audio/video. Once you are on the right input, use your CABLE remote to change the channels. DO NOT USE THE TV REMOTE.
Jul 18, 2011 | LG Televison & Video
"Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No channels found
you have reseted your box to manufacturer default values....if you are not having correct parameters(trans. no., symb rate,etc) of your satellite then you have to contact the service man...before that , make a blind search of channels with trans freq 05050...this may get you..
Aug 19, 2009 | Televison & Video
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
