Question about Linksys Wireless N Gigabit Router
Am i connected?
I did everything that was in the CD yet it says I am not connected properly. What else can I do?
    Novelist:
  • 144 Answers
Hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Posted on Jun 10, 2008
Why is my amp only coming on when my f.m radio on its not staying on when I switch to Aux or cd. Everything has power
Your amp is still on - issue is that the connections to your aux and cd inputs are not properly going thru the preamp circuits and reaching your amp inputs.
Jun 20, 2017 | AMP Car Audio & Video
Cd player won't play. What's wrong with it.
If everything seems to be functioning properly, the CD is spinning, and the second counter is going up. I would check the connection from the speakers. Whether it is wired or plugged in it may just be a bad connection. For a better idea on what may be happening you will need to provide more information.
Oct 02, 2016 | Audio Players & Recorders
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
Order 10765358-273Do you have the answer to lem yet?my prob
Please remove the usb cable from the computer and printer and reconnect again and check it that is it printing properly. If it not working remove the printer from the computer then uninstall of the printer software and reinstall from the cd, when it ask to connect printer then only connect the printer after that it will print properly.
Mar 19, 2012 | Polaroid PoGo Digital Photo Printer
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
I installed radio everything works except no sound from aftermarket speakers. Radio was hooked up in another car everything worked fine!
Double check your speaker connections. Make sure + goes to plus and - to minus (phase) and make sure all are grounded properly. Is there an amp possibly in line? If so, make sure connections are good there also make sure powered up (it happens to all of us)
Feb 26, 2011 | Kenwood KDC-MP228 CD Player
I have a Fatal1ty FP-IN9 SLI motherboard installed in the case with a 750 watt power supply. I turn on the power, and it runs the Plextor CD writer with an XP installation CD and does not boot the hard...
If there is a disk in the cd device the bios is set up to boot up from there first. So if you have a xp OS disk in there that is what will happen . Remove the disk and it should boot from the hard drive if it is properly loaded.
Sep 09, 2017 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
I took my toshiba apart to put new fan in. now i only get the power light when i turn it on and it doesnt come on the power light isnt flashing its just on
You might want to check all the connections, it sounds like the HDD isn't connected properly or something. Failing a bad connection somewhere, you mat need to take it to a professional repair shop as something may have become damaged.
Feb 25, 2010 | Toshiba Satellite A45-S150 Notebook
Installed sony cdx-gt280 in car, everything works fine until cd is inserted and then the head unit starts to flash on and off continually. Do you have any idea what might be wrong?
When you run a CD the radio needs more current then when you are using only the tuner.
Check that the positive power cable is connected properly and thick enough. Do the same with the ground... I have had this when the ground cable is not connected properly or too thin.
Try grounding it straight to the battery or body with a thicker cable
Nov 03, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
I need to know if I put it back together right
If you pulled it apart and put it back together but now it won't work properly, try checking your IDE cables to the hard drive/cd-rom, make sure they aren't connected backwards. Otherwise just carefully look over the entire board, be sure that the processor, heat sink and fan assembly are all intact and connected properly, do the same with the RAM, power connection, any expansion cards.
May 06, 2009 | Computers & Internet
Linksys Wireless N Gigabit Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
