Question about Dell Inspiron E1505 Notebook
Hello, i got a dell inspiron E1505 ,which is showing that the radio it disabled thus i got no wireless connect.I would be happy if you can advice me on how to enable my radio
    Guru:
  • 846 Answers
  • Double-click the "QS" icon in the system tray to launch the Dell QuickSet utility.
  • Click the "Radio Control Options" icon in the upper-left corner of the QuickSet window.
  • Click the "Advanced Settings" button and select the "Radio Control Options" tab at the top of the window.
  • Place a check next to the WiFi device and then click "OK." You should see the "WiFi" indicator light on the bezel above the keyboard turn on. If the indicator turns on, you should now be able to connect to a wireless access point. If you continue to experience a problem, continue to the next step to confirm that the adapter is enabled in the Windows XP Device Manager.
  • Click the "Start" button. Right-click the "My Computer" icon on the Start menu and select "Properties."
  • Select the "Hardware" tab at the top of the System Properties window and then click the "Device Manager" button.
  • Double-click the "Network Adapters" category.
  • Right-click the Device Manager entry for the WiFi adapter and select "Enable." You should now be able to connect to an access point.
Posted on Oct 24, 2010
SOURCE:
Reinstalled Vista and now it will only do a local connection.
http://www.opendrivers.com/freedownload/250725/dell-inspiron-e1505-notebook-wireless-%28us%29-wlan-card-driver-4.100.15.5-4.100.15.8-windows-xp-download.html
Go to this link. Install the software, May be it will help you.
Jan 03, 2011 | Dell Inspiron E1505 Notebook
I replaced the hardrive on my dell inspiron e1505 when the original died but now it does not indicate a wireless connection area-do i need to replace a wireless card?
No. You need to install the driver for the wireless adapter. Go to the Dell website under support, enter your service tag number, go to driver downloads, download the driver for the adapter, and install in your computer.
Dec 14, 2010 | Dell Inspiron E1505 Notebook
My dell inspiron e1505 will not display available
make sure the wireless card or adaptor is active with updated software and drivers.
Apr 30, 2010 | Dell Inspiron 1501 Notebook
My Dell E1505 won't allow me to go wireless. My
Ideally, see if we can isolate the issue.
Disable the built-in antenna.
Try connecting to the wireless via a USB wireless antenna. (hopefully you can borrow one).
If you can connect, then I would say you need to replace the built-in antenna. Or you could keep using the USB antenna.
Good luck
-Carlos:
Jan 25, 2010 | Dell Inspiron E1505 Notebook
No sound from speakers after BT installed
Keep the BT connected and do a system restore.
Sep 10, 2009 | Dell Inspiron E1505 Notebook
I cannot connect to my wireless internet Dell Inspiron E1505
what does the it say? limited connectivity? etc. or it just can't connect at all?
Aug 16, 2009 | Dell Inspiron E1505 Notebook
I have media direct on laptop inspirion 1505...it was not being used and now it comes on automatically and i can not get to opening page for password to internet. when I exit media direct express, the...
First hit ctrl-alt-del at the same task manager will open and you can shut it down there then go to control panel and click on add/remove programs, select media direct and click uninstall
Jul 27, 2009 | Computers & Internet
My Dell Inspiron E1505's wireless switch is off.
This happened to me using a Dell Inspiron laptop. The wireless switch was disabled and the answer was supposed to use both the blue Fn and regular F2 function key to enable wireless connection. I tried Fn and F2 together and it did not work. I tried just F2 alone and it worked.
Jul 25, 2009 | Dell Inspiron E1505 Notebook
Inspiron E1505 laptop won't let me get a wireless connection
Check the control panel their should be a icon in there for wireless. Click on that and follow the steps. I had the same problem and for some reason it started working when I use that icon.
I hope this helps, please rate.
Feb 19, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
211 people viewed this question
Ekse
Clive
Clive
