Question about Sony Xplod XM-554ZR Car Audio Amplifier
Sony explod 800W amp
Hi
I went to use my car stereo and found out that there was no power to the amp. So I looked at the fuse between the car battery and the amp,, yes it was blown. I replaced with a new fuse(30 amp) and now the light that is normally green on the amp is RED. I checked the two 30amp fuses on the amp itself and there fine. I checked the ground wire and cleaned it up, its fine. So what I think I need to do is RESET the amp,, and I don't no how, does anyone now how to reset the 800w sony explod amp?? It has power because the light is red,, all fuses are fine.....I'm stumped. Thanks for the assistance.
-Shawn
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Posted on Jun 08, 2008
I need help with a battery drain on a 2002 GMC Yukon Denali XL
As odd as this sounds, I would take it to "Car Toys" and have them take a look at the stereo wiring.
Apr 29, 2014 | GMC Yukon Denali Cars & Trucks
Instrument panel went dead after i installed aftermarket stereo
first check the factory wiring for your vehicle. sometimes the red wire is not the battery power. In my car the orange wire was battery power and red was the accessory power. also make sure the ground wire is attached securely. Then check your fuse box. I had a 10 amp fuse blow and because the aftermarket stereo drew more power than the factory one I needed to put in a larger fuse.
Jul 03, 2012 | 2004 Pontiac Grand Prix
Hi. I keep blowing inverters. I had a 1200 watt Coleman that went out while running a fan. Just installed a Cobra 800w inverter in my Dodge Ram under the center console. I had it wired to an outlet on my...
Well without knowing exactly how you wired it, it is hard to say what happened. A little diagram would help. But, with nothing plugged into the inverter, the wires must have been shorted. What size wire are you using? If you have an 800W inverter, the amperage on the secondary, (120V) side is only about 6.5 amps. So if you ran 14 ga wire (smallest you should use on 120V ) that should be fine for the 120V circuit. Do not connect any of these wires to anything but your remote receptacle. Now for the primary. Notice how large the terminals are on the supply side, if you have an 800W load @ 12V that would be approx 66amps. Therefore you should have #4 or #6 copper wire going from the battery to the inverter. This wire must be fused, and I'd fuse it with a 60A fuse. You can buy nice fuse holders like they use on amplifiers that connect right to your battery. Now on the 1200W unit, you can imagine the difference. The secondary would be 10amps and the primary would be a whopping 100A. Even if you have a large alternator, I'm sure it is not rated at 100 amps continuously.
Oct 19, 2010 | Duracell Portable Digital Inverter - 800w...
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
I installed a scosche 500k micro farad capacitor in my truck. i have a 800w sony explode running a volvonhag 12" sub, the doors are run by a rockford 40i amp. sounds great till capacitor hook up. amp cuts...
You need to put the capacitor after the in line fuse/ distributor block. Because you are putting it on only your subs you are running it into fail because of a negatuve ground loop which is why they play low then cut out. Also check your grounds for both amps after rewiring and make sure they are tight.
Sep 07, 2009 | Car Audio & Video
How to fix rockwood 10 in. 800w sub?
i would double check your connections also any fuses on the amp i have blown a few fuses on my amp haven't checked into the main reason for that to happen but its common if you don't have a big enough amp... assuming that the amp is getting overloaded. I would say you need a bigger amp like 1600watt or 1800watt
Jul 30, 2009 | Car Audio & Video
I have 800w majestic amp it won't turn on what parts do i need to fix it amp is 2oyrs old
have you checked the fuses on the amp if so you can try to check for power of the amp straight from the battery by connecting the remote wire and power or battery wires together putting them on the positive terminal on your battery and the ground or earth wire on the negative terminal on your battery if there is no faults it should light up
Jul 26, 2009 | Majestic MA6300R Car Audio Amplifier
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Pioneer GM-D7400M Amplifier Flashing
sent it to service center because the problem is inside the amp -sometimes electronics component failed by heat or bad ventilation or poor design work
Apr 14, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Sony Xplod XM-554ZR Car Audio Amplifier Logo
276 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
