Question about MSI 845E Max2 LR Motherboard
How can I connect the Power switch to the Msi 845E Max2 motherboard?
SOURCE:
map9966
  • 2351 Answers
SOURCE: intel 845E TR100 motherboard
Just click the link & download the pdf.
http://support.intel.com/support/motherboards/desktop/d845ebg2/sb/CS-008633.htm
Please vote............
Posted on Jan 16, 2008
jfar_22
  • 9 Answers
SOURCE: MSI 845E Max P4/845E/FSB 533/HT/Audio/ATX Motherboard
Try this link..http://www.nodevice.com/driver/845E_Max/get37906.html
Posted on Jun 29, 2008
mbase213
  • 728 Answers
SOURCE: Power switch,reset switch,power led connections to motherboard?
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
Posted on Apr 25, 2009
  • 91 Answers
SOURCE: how to connect msi 845pe max2
this is the manual link this might help
http://premioinc.com/pc/manuals/mb/845pe/845pe.pdf
Posted on Feb 22, 2010
  • 39 Answers
SOURCE: how to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
Posted on Apr 15, 2010
What's your problem?MS-7207 VER:2.0 I TOOK THE 3 CONECTORS OFF AND DONT KNOW WHERE THEY GO BACK
Hello you can download a manual here:
http://www.msi.com/product/mb/645E-Max2.html#/?div=Manual
The pinout should look like this:
Its also printed in on the mainboard with very small letters.
Make the connection propely and the computer should start again.
Powersw goes to powerswitch etc.
Good luck
Aug 21, 2012 | MSI 645E Max2 (MS-6567) Motherboard
Connecting the mic
Download the manual from the MSI motherboard sitehttp://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=487
exists in 6 languages, and it is explained very well...if you need more help, you welcome.
Nov 26, 2008 | MSI 845E Max2 LR Motherboard
Jun 26, 2008 | SIS741GX-MN Motherboard
Surge Protector
Surge Protectors are devices that usually you plug your equipment to.. and it protects it from Voltage Spikes that would otherwise destroy the device without it.. saddly not all Surge Protectors are the sam.. some are completely useless..
If you are really serious about protecting your PC not just the hardware but also the data and your work.. might as well invest on a UPS(Uninterrupted Power Supply) unit.. it has everything a surge protector can offer and more..
Apr 28, 2008 | MSI 845E Max2 LR Motherboard
USB Power Surge
try uind using a power bar surge protection peace out jules
Apr 27, 2008 | MSI 845E Max2 LR Motherboard
I have msi motherboard and i need the sound card driver becouse there is no sound .......
1st yougo your motherboard 845E MAX2 home site.
then go to driverzone.com
or
drivercollection.com
Feb 27, 2008 | MSI 845E Max2 LR Motherboard
Having problem with power leds on motherboard Please help!!!
If you've got the manual goto Chapter 2 page 39 for the arrangement diagram, if your power led is a three pin spacing design use JFP2 otherwise use JFP1, just incase you didn't know pin one is the one with the arrow above it on the back of the plug, the diagram will show you the order, if you don't have the manual you can download it as well as all other updated software and drivers here:
you will need Adobe Acrobat reader which can be downloaded Here:
http://www.adobe.com/products/acrobat/readstep2.html
and if your version of windows is below XP you will need a unzip program eg.Winrar that is downloadable Here:
http://www.rarlab.com/rar/wrar371.exe
It's only trial software but it will get the job done, hope this has helped you.
Oct 30, 2007 | MSI 845E Max2 LR Motherboard
MSI 845E Max2 LR Motherboard Logo
43 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
