Question about Compaq Computers & Internet
My vertical scroll does not word. i tried to change settings from the control panel but it didn't work.
  • 146 Answers
It should be the problem with the hardware. Try fixing it by taking near laptop service center. Thank You
Posted on Oct 24, 2010
SOURCE:
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
I have kensington USB mouse for Mac. I accidentally set the vertical scroll to horizontal, and now don't see the icon in the top menu bar where I can go to change it back. How can I change the scrolling...
(I don't really do Macs) but, find your control panel, mouse settings..
Have you tried removing the usb dongle, restart the Mac, then re-insrt mouse dongle?
Jan 10, 2011 | Computers & Internet
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
HP Pavilion dv7-1285dx vertical scroll no longer works
the problem is with your drivers only:-
1. you dont have installed the drivers for ur touchpad if is that so, then it is not properly installed . pls uninstall old drivers reinstall the touchpad drivers and restart the system and the problem will be resolved. doing this will reset all the changed values that you don't know and load the default values which will work fine. 2. Secondly you can also try by going in control panel and go to tochpad settings , reset to default. it will work. but first one is best thing
Jun 14, 2009 | HP Pavilion dv7-1285dx Notebook
Vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Not working for my vertical scroll zone howcan activate this problem
Assuming you're talking about the touchpad, this can be enabled and disabled in your control panel.
Open your start menu, then Control panel, if it's not in classic mode click the Classic View link in the top-left corner. Now open the mouse icon and select the Device settings tab(red logo), now click the settings select by single clicking the synaptics touch pad from the list. click the settings button below the list and select the "Virtual Scrolling" section.
You will see two check boxes, the First enables the marked off vertical scrolling feature, the second enables a horizontal scrolling feature that may not be marked on the mousepad but runs along the bottom of the pad and works the same way.
Click OK, on both windows and close the comtrol panel.
Hope this helps FixYa, if not reply back with any additional info you can,
Chris
May 12, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
