Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows Vista. There is no drive letter assigned or any sign of the device under the Device Manager.
    Brigadier General:
  • 10,406 Answers
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Posted on Oct 24, 2010
SOURCE:
Wdbaaa5000asl
The PC will not detect a drive that is not spinning. Make sure the power plug is seated properly.
Jan 11, 2014 | Western Digital My Passport Essential...
How can I play music from my desktop backup disk (My Passport 1GB) via USV in 2012 Toyota Tundra
You need to format the hard drive to FAT32 and then copy your 80Gb of music files to this hard drive.
Mar 27, 2013 | Western Digital 1TB My Passport Essential...
My passport cannot be detected by any computer. the light blinks when I plug it,and does not function.
The quickest way to troubleshoot this, is by unplugging all other usb devices, not the kb or mouse. Then plug in the drive and see if the pc recognizes it.
Nov 08, 2010 | Western Digital Passport WDXML800UE...
Its a western digital WD passport 750GB portable drive and its not showing up on my computer. I can see the blue light and feel it running but not registering on the laptop or desktop
Usually what has happened here is the usb interface has failed. The little hard drive with all your data is perfectly fine but the interface can no longer talk to the computer.
There are a couple of fixes. One is to send it in to WD who may or may not preserve your data. You can buy another passport and take the drive out and put it into the new drives enclosure. And third which is the way I've been fixing these is to go buy a usb drive enclosure. These start at $15 and up. Then you just take the drive out of your passport, plug it into the enclosure and you are back up and running.
This type of failure is common to all manufacturers.
The enclosure swap is something you can do yourself. The hardest bit is actually opening the case on the passport. Any computer shop should be able to do it for about $40 or less.
Sep 29, 2010 | Western Digital WD Passport 250GB Portable...
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
Western Digital removable HD devise not found
For Western Digital Passport make sure you use the prigina;l USB cable or a replacement. They are not all the same. WD uses a propriatary cable with an extra power line I believe.
Apr 12, 2009 | Western Digital Passport WDXML800UE...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
My passport essential
This is mostly a power issue, although higher speed devices also tend to need shorter cables due to latency. Light & electricity travels about 1 foot, or 30 cm, in a billionth of a second; this limits the size of high speed devices. In layman's terms, latency is the Brontosaurus effect, since the head takes a while to talk to the tail.
Western Digital recommends using a 22" USB 2.0 Power Booster Cable (WDCA029RNN) to combine the power of two USB ports into the one Passport Essential USB port--it is also a bit longer than the original 18 inch cable. For all EXCEPT the black Passport Essential drive, you may also the WD Passport™ Power Supply Adapter (WDPS021 for the US voltage version). See Western Digital knowledge base ID 1296 for more on this issue. Also see ID 1048 for European Support info.
Hope this helps!
Apr 30, 2008 | Western Digital My Book Essential Edition...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
192 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
