I would a manual
I would like a manual for my Sylvania 6260VF VCR
    Novelist:
    Champion:
  • 254 Answers
Check here http://www.sylvaniaconsumerelectronics.com/pdf/om/6260VF.pdf
Posted on Jun 12, 2008
Old tapes recorded wont track speedup slow down
Hello; This can be a very complicated issue. The simplest, is a dirty control track head located on the output (or right side of the drum containing the video heads). It is just before the pinch roller. Clean well with isopropyl alcohol 91%. The second likely thing is a damaged tape, that has a creased bottom edge caused by a defective VCR that has excessive reel takeup torque that causes this tape to crease while playing it. Open the cassette door where the problem is and check the tape for a bottom crease. usually about a crease 1/32 of an inch or more from the bottom. Tapes that are creased cannot be saved. John
Dec 15, 2010 | Sylvania 6260VF VCR
How do i adjust tracking. tapes roll. used a cleaning tape, didn't help. there is no switch for manual tracking.
Cleaning tapes are not as good as going in with a can of Servisol Video 40 and some cotton buds. Take the top cover off and give it a really good clean with them. Clean everywhere the tape touches. Make certain you allow to dry before trying again. If that doesn't work you could have a faulty head.
PS it will take longer to clean if it is housed in a room where people smoke!
Sep 30, 2010 | Sylvania 6260VF VCR
Get nothing but static when i turn it on
make sure you go from the cable box were it says out to the in on the vcr from the vcr you want to come out to the tvnow you can program the the vcr to pick up the cable chanell from the boxthe vcr has to be on chaell 3-4 in the front were it shows what chanell your on then the tv and the vcr are to be on the wright cahells the tv has to line up with the chaell your useing for the vcr3-4 to make this less complicated put a tape in the vcr hit play if its playing you are on the right chanel you do not have to have the vcr to watch cable it will go threw even if vcr is off just have to be right chanel
May 18, 2010 | Sylvania 6260VF VCR
How do I record from tv to vcr . I wouldlike to upload a manual for sylvania vcr/dvd model 840f or similar product.
www.devicemanuals.com/.../Sylvania/Sylvania-DVC840G-DVD-Dual-Deck-4HD-Mono-User-TmpJMU5EST.html -
here is the manual
good luck hope it helps
May 15, 2010 | Sylvania DVC840G DVD Player/VCR
Clock will not keep time
Aside from resetting the time to the correct time every once in a while, it's not worth fixing. I have a sharp vcr that the clock starts to run fast 2-4 weeks after i set it.
And another thing to check is to make sure the VCR is not plugged into a socket that activates with a wall switch that you might turn on and off everyday.
Apr 10, 2010 | Sylvania 6260VF VCR
Timer recording, more than 1 show
I have no solution how to fix it. My idea is . Use the One-touch timer Recording (OTR) on page 27.
If your manual is the same as mine. My VCR recorder is broken.
Aug 29, 2008 | Televison & Video
Tracking
A CONSTANT streak anywhere on the screen could be a scratch in the tape itself. Losing sound, and ocassionally everything going to black and white, sounds like a dirty control track head.(The audio and control track are in the SAME head (a 3/4" metal cube that the videotape travels on). The control track section is on the upper part, and the audio on on the lower part.
If the control track head's dirty I'm sure the rotary head's dirty too! Losing audio and have tracking problems, point to dirt. And you MAY have SO much dirt built up on that head it's scatching your tapes (unrepairable), and causing you problems. Make sense?
Mar 16, 2008 | Sylvania 6260VF VCR
Tracking
Does this happen on ALL tapes?
Depending on WHICH model VCR you have (old or new) SOME have a switch which will allow you to adjust tracking MANUALLY. When the switch is in the manual position, it won't track automatically. If some played with that switch, that could cause your problem.
ALSO, do you have a cleaning tape? If the control track head is dirty, it won't see the "control track" (which gives you VCR information to control the tracking.
Another possibility is one of the video heads (there's 2 or 4) is dirty, and without ENOUGH video signal coming off the heads, it's not possible to track properly.
Try running a cleaning tape through. If you've never done it, it might be time. Unless yu know about equipment I'd wouldn't suggest you open the machine and clean it yourself. Let me know how you make out.
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
