Question about GE DBSR453EBWW Electric Dryer
GE DBXR463ED2WW dryer making loud sqeaking noise when full load in dryer? What is causing this and how can I fix
    New Friend:
There are some pads that are like teflon that the drum rubs on. get some more and re place
Posted on Oct 26, 2010
6ya staff
SOURCE:
Ge gas dryer making loud noise
what kind of loud noise ? is it a sqeaking/squealing noise ?
Jul 22, 2014 | GE DBXR463GB Gas Dryer
My GE Dryer Model # DBXR463ED2WW makes loud squealing sound when it runs loaded. Is this something I can fix?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 11, 2010 | GE DBXR463EDWW Electric Dryer
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
My dryer is sqeaking loudly when running
Squeaking usually comes from drum roller supports and/or the belt idler pulley needing lubricated. If the drum does not have drum roller supports under the drum, it will be equipped with a plastic drum glide the is located around the perimeter of the front drum facing. If this plastic wears down it will cause the drum to scrape against the metal bulkhead and make noise. If equipped, you need to replace the drum glide
The drum rollers (if equipped) can be lubricated with a light weight turbine oil (like the kind you would lubricate some ceiling fan motors with). Lubricate the roller wheels at the axle ONLY. Do not lubricate the wheels. The same is true for the idler pulley. Make sure you don't get any oil on the belt, or it will slip.
If you need instructions on how to reinstall the drive belt, repairclinic.com has dryer belt diagram illustrations under their "Repair Help" section. Look for the "Dryer Belt Diagram" link on the left hand side of the page. If your dryer is a GE model, you would use diagram M, D, or L (depending on the age of the dryer).
If you have questions, let me know. I hope this helps you.
May 06, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
GE DBSR453EBWW Electric Dryer Logo
742 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
