Question about Sony STR-DB940 Receiver
Sony STR-DB940 No output technical question.
I just bought cheaply at an auction a Sony STR-DB940/ FM STEREO/FM-AM RECEIVER. It was touted to be working, and power up is good. Selectors, DSP, Tuner all work and audio is accessible via pre-out (2ND AUDIO OUT).
All output though is dead.
Opening up the unit you I found both fuses (125V 8A) on DC (1) are blown. On replacement they blow immediately. The only output on the board (CNP802) feeds Main Board with B+ and B- 61.1 V. Looks like this is the main amp/ booster that then feeds each bias board.
My question is what would be the best method of fault finding what is shorting out/ loading the circuit? I cannot feed the power the check voltages. Has anyone come across this and got ideas in what could be wrong?
Thanks in advance.
Tim
2 Suggested Answers
  • 163 Answers
SOURCE: Sony STR-DE945 8A 125v fuses
Check HomeDepot they have 7amp , maybe your store has 8amp.
Posted on Dec 18, 2009
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
I have a sony str-de335 fm stereo receiver and
This can be shorted output transistors (common) or a defective voltage amplifier IC. WIthout taking measurements inside, there is no way for me to make that determination. In any case, this should be a relatively simple repair for a shop that repairs audio gear. Expect a parts cost in the $25-$40 range.
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
Need fm wire antenna and am loop antenna for stereo receiver
Could be bought at Radio shack, not the original Sony model but an aftermarket that will do the chore.
Feb 21, 2009 | Audio Players & Recorders
Sony str-db940
Most likely a cold solder joint somewhere in the audio circuit. Most likely on the legs of the relay that turns the speakers on or off. Also check the connections at the audio outputs. Give it a good look over for bad solder connections, given the symptoms that's 98% likely to be the problem.
Oct 06, 2008 | Sony STR-DB940 Receiver
Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
May 27, 2008 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Logo
264 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
