Question about Asrock 939SLI32-eSATA2 (939SLIESATA2) Motherboard
Hi, please i have N73Vs Board but lately when i shut down the pc,it will shut down but the board doesn't go off so i have to remove the power cable before restarting.pls help me out. Thanks Quophi
SOURCE:
Blue Hammer
  • 167 Answers
SOURCE: shutting down
Yes mostly this is the case that your system board is faulty. You should get your motherboard serviced. If it is still under warranty you may get it replaced.
Posted on Sep 27, 2007
  • 113 Answers
SOURCE: Powers on for a second and shuts down
6ce1e4e.jpgmanual:
http://72.14.253.104/search?q=cache:rM03zfMddCsJ:ftp://download.asrock.com/manual/K7S41GX.pdf+Asrock+K7S41+Motherboard+manual&hl=en&ct=clnk&cd=2&gl=au
i am getting you this manual cause you can check what i am about to tell you here. make sure the jumper plugs are on the correct pins and that the BIOS settings match the configuration you have and especially make sure the power,reset,led,led2,powersw,speaker,sys pins that come from the power button and so on are over the correct pins on the motherboard!
good luck!
Posted on Oct 10, 2007
map9966
  • 2351 Answers
SOURCE: swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Posted on Nov 03, 2008
alpug
  • 1961 Answers
SOURCE: I have an E-box computer
the problem merely on the hard disk.the hard disk is not stable there must be bad sector on it that after the installed program reach the bad sector the problem occurs .It's going to crash replace your hard disk or the to run scandisk on other computer and scan your hard disk....click tthe automatic fix bad sectors ...thank you and good luck!
Posted on Aug 21, 2011
skipper86
  • 153 Answers
SOURCE: Windows freezes when shutting down
Download and install RegInOut System Utilities program. Run all its tools one by one except Internet Optimizer. This will allow you to clean junk from your computer folders and repair registry errors. Restart your PC and problem will be vanished.
Posted on Sep 08, 2011
Hp touchsmart 310 pc power flashes 3 times and won't start
people,people please I know I saw it too late but this is the solution
replaced the Power board button with the cable that goes from the power button board to the motherboard.
part # 625223-001 (hp touchsmart 310 swith board(Shasta)
thank you.
Feb 10, 2012 | Computers & Internet
Turns on, then shuts down before anything shows on monitor
Hi m5mm, what kind of Operating system are you using?
Jan 03, 2008 | Gateway GT4022 PC Desktop
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
Power remains on board after shut down. Cpu fan still runs and usb still powered as the power unit does not switch off.
Hi Peter ,
If it is a desktop , unplug the power supply cable .
If it is a laptop , unplug power supply cable if connected and remove battery anyway .
Best regards
fanaudi .
Apr 27, 2011 | Computers & Internet
Computer is on but blank screen
Check the RAM .
If the problem is same . remove the cmos battery and install again.
Reply me soon.
Hope this help.
Feb 19, 2011 | Intel Motherboard
Im trying to put in my power button on my hp 60 230 us notebook pc
Power button board 496830-001
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then
unplugging the AC adapter from the computer.
4. Remove the battery (see "Battery" on page 4-7).
5. Disconnect the wireless antenna cables from the WLAN module (see "WLAN module" on page 4-15).
6. Remove the keyboard (see "Keyboard" on page 4-17).
7. Remove the keyboard cover (see "Keyboard cover" on page 4-20).
Remove the power button board:
1. Remove the two Phillips PM2.0x4.0 screws 1 that secure the power button board to the keyboard cover.
2. Remove the power button board 2.
Here is the service manual: See page 4-22
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | HP Computers & Internet
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
My daewoo pd46c10 doesn`t power up when I turn it on. If I go to the t v itself I can turn it on but all that comes up is the daewoo name in large letters. It was working fine when it was shut down last.
You have either Bad Capacitors on the power supply board which they will be vented,swollen or puffed up on top 2200uf 10v 3300uf 10v 220uf 25v or Your Main board which is the board that has cable connector on it.
Sep 10, 2010 | Televison & Video
HP power up issue
hi
you will have to remove the power cable and hold the power button for 7 sec w/o power cable and then try connection the power cable and turn on
2) reset the power connector on the mother board and try it
3) remove the memory and chk if you could listen to the beep if yes the mother board and power supply is fine so try removing the pci cards if any
Try those things
Regards
Samson Ved
Dec 10, 2008 | HP Media Center m7260n (EG642AA) PC...
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Asrock 939SLI32-eSATA2 (939SLIESATA2) Motherboard Logo
131 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
