I have a problem with 19" LCD. Could not get 1440x900 resolution. I did some research on the web and I would need to update bios to 2.28.00 version. Where I can get this version and how to do it?
Your help would be appriciated.
Do you need the bios update for your video card or motherboard that has onboard video where the blue/while socket for your monitor are close to the keyboard, mouse and USB ports?
I may also need to ask you a few more clarifications to be reasonable assured we are updating you correctly. This last part is important, more important than you may imagine as an incorrect bios update procedure could disable your PC.
-   I
have Samsung SincMaster 2053BW monitor, but the PC doesn't support
1680x1050 resolution. The MB is k7som+ Model VersionV7.5C. I changed the original BIOS with newest version I
found on the ECS page and video driver, but have no result.
What have I do? Can I download newer version of VBIOS and will it solve my problem?
-   al_yankov
Sep 28, 2008
-   I got the 1440x900 resolution on the onboard graphics chip but the refresh rate is all wrong. I'm currently trying to update the graphics driver I'll let you know how it goes.
-   drabir
Aug 20, 2008
-   Hi,
-   Guest
biostar p4m900-m4 built machinedepress power button and system fans and processor fan turn for just...
(More)
biostar p4m900-m4 built machinedepress power button and system fans and processor fan turn for just a split second and stop
After installing this motherboard, k9a2vmfd, I found that it will post and as long as I leave it...
(More)
After installing this motherboard, k9a2vmfd, I found that it will post and as long as I leave it plugged into house power. But, if I unplug it to move the tower, then attempt to turn it on, the lights come on but no post. Once I experience the no post and restart the system it continues to start normally until it is unplugged again. What's with that? Help!
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything...
(More)
I purchased a Gateway DX4822-01 with an Acer GT43-AM V.2.0 motherboard. I am transferring everything from the OEM case into a HTPC 8000 Media Center Case. I need to know the F-Panel pin configuration in order to hook up the power on, reset HDD led etc. I could really use the manual for the motherboard but Gateway is telling me they don't have it.
Hope you can help.
Thanks
