Question about Zodiac Pacer Pool Cleaner
Hi, we have a Zodiac pool creepy crawly pool cleaner which seems to work for a while, then get stuck in the one spot and not move in our inground pool.
  • 640 Answers
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Posted on Oct 26, 2010
SOURCE:
My creepy crawly works for a little while then stops.I have 50kpa pressure at the filter
Check for debris or obstructions that could be lodged in the flapper of these pool cleaners. That could be restricting movement and causing the cleaner to stop cleaning. Check to make sure that it is not sticking on the main drain. If the main drain is not closed, missing a grate, or not flush with the pool bottom, it could be sticking. A pool pro would have to do some work to fix these problems (except for closing the main drain).
Jan 13, 2011 | Universal Kreepy Krauly In-Ground Pool...
Recently bought a bull shark creepy from Mica Benoni, and although it does clean the pool ( when it is is facing down), it climbs the walls ( sometimes and falls over onto its back and stays there the...
I have the same problem as well. There is nothing obstructing the the kreepy from sucking. This seems to be a general problem with the bull shark. I have gone to the pool places and without me telling them about my problem with the kreepy they told me what the problem is with the bull shark. My friend has the same problem with his. Mabe there is someone that work for kreepy crawly that knows how to solve this problem.
Jan 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
I have a Zodiac Baracuda G3 pool cleaner once the the pump switches off at night the next morning creepy does not sit flat on the bottom of the pool the front side stands up in the the air if you lift the...
It sounds like your house weights need to be adjusted. When the pool cleaner is resting, it should always sit at a 45 degree angle on the bottom of the pool. If it stands up on the front side, try sliding the weight away from the cleaner head. You may need to make several small adjustments to get the balance right, but this is almost surely your problem. Here is a copy of the users manual if you want to read more about hose weights and balance:
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Oct 11, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac has suction but doesn't move
With these pool cleaners, that is often a problem with the flapper. Check the flapper to be sure that no debris is stuck. Debris can halt water flow and movement, making your cleaner get stuck.
Jul 11, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Creepy crawly tangles
You will need to take the hoses out and lay them flat in the sun for a day or two and while you do this take the head to the store and have them caeck the swivel at the top of the mast head. Good luck.
Mar 30, 2010 | Pool & Spa
The Hayward creepie crawlie that cleans our pool works fine until it comes to the steps - then it stops - head towards the steps - and if it does move again, it turns over. Do I need to get a rebuilding...
Make sure there is extra hose and extnsion cord to allow the pool cleaner to manuver around the entire pool floor. I don't know why the pool cleaner has problems with steps, was there a tramatic fall down a flight of steps or something.
Aug 12, 2009 | Pool & Spa
Barrcuda inground pool cleaner flips over
Often when you are having this problem with automatic pool cleaners, it has to do with the hose. Make sure that you have plenty of slack in the hose to cover the entire pool. Also, make sure that you do not have any obstructions in the hose and that it is not tangled.
Jun 13, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
Does not clean the whole pool
may need to re-weight it or add helpers.
I had to add a rope system to my pool to get the creepy crawly to all the spots.
Not the best fix - but keeps the pool clean.
Apr 10, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Pacer Pool Cleaner Logo
1,748 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
