Question about Sewing Machines
Need foot padel - Sewing Machines
    Genius:
  • 1,788 Answers
Without the model and make no one can help you. There are lots of places to buy one but you need to say what you have.
Posted on Oct 24, 2010
SOURCE:
Model 830 Bernina pl wiring diagram padel to motor 3 way socket
Request the model 830 wiring diagram from Bernina.
Jul 21, 2018 | Bernina Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
When I push my padel an error #1 shows up on the screen
Make & Model ??
....do you have a manual ??
Nov 15, 2011 | Sewing Machines
White speedylock serger 7340 I need the manual and the power cord and foot padel
Singer has the manual for the White 7340 on their site, http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search. The direct link to the manual is http://www.singerco.com/uploads/download/988_sl-7340,299-x.pdf . A universal cord and pedal are avalable here: http://www.sewingpartsonline.com/white-7340-sewing-machine-parts.aspx . This site also has a printed copy of the manual for sale.
I hope this helps.
Oct 16, 2011 | White Sewing Speedylock 1600 Mechanical...
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
I pressed the power padel, but the needle does not go up and down. Why
You may need a new foot pedal, or you didn't make a stitch length selection. Does it move up and down when you turn the handwheel towards you? Try unplugging the machine and plugging it in again. It is hard to diagnose when you didn't say what kind of machine it is, or the model number. Please supply that information and maybe I can help you.
Apr 06, 2011 | Singer Sewing Machines
How to sew buttonholes
First thing you'll need to do is switch the presser foot.
Your machine should have come with a specific button hole foot.
(might have an R on the bottom)
To snap off:
Raise the needle and presser foot.
Press the red button on the back of the foot holder
and the foot will drop.
To snap on:
Place the presser foot so the pin on the foot lies just
under the groove of the foot holder.
Lower the foot holder to lock the foot in place.
Select which buttonhole style you would like to stitch.
This can be done by selecting a mode (buttonholes are 06-08)
and then adjusting to the desired length and width.
After you do this, lower the presser foot and hold the foot pedal down.
The machine will automatically sew the buttonhole and stop when it is finished
All you'll need to do is just cut the thread after.
Hope you found this information helpful.
Mar 17, 2011 | Janome DC3050 Computerized Sewing Machine
I have toyata model 2702 EC1 series i need the foot padel. can you help?
If you just need the foot control you can buy a standard type usually YDK, if you need the harness as well you will need to take a drawing or picture of the plug on your machine so the dealer can match it up.
Mar 06, 2010 | Sewing Machines
Control Box Wiring Diagram for Bernina 830
Berinan 830 record electronic sewing machine padel to machine 3 way socket wiring diagram
Sep 30, 2008 | Sewing Machines
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
