Question about Husqvarna Viking 1
I am experiencing difficulty in stitching shade cloth. I have thread provided by the shade cloth manufacturer, and am using denim needle, as recommended by the shade cloth people.The machine is locking after only a few stitches and is clearly not happy with the job. I have a Husqvarna 2000 Model 64 40
  • Husqvarna Master
  • 1,134 Answers
Probably just too heavy for the machine to handle and the thread may also be too thick for the bobbin to tension correctly.
Thread above 50 gauge is not suitable for domestic sewing machines and it is likely that that is what the shade cloth manufacturer use through an industrial machine.
You could try again with regular good quality polyester thread, a roller foot and very careful slow stitching with you helping on the fly wheel and see if it works?
Posted on Mar 14, 2011
SOURCE:
What size universal needle can be used
The size of the needle is determined by the fabric and thread you are stitching. Heavier fabrics and threads will require larger needles. Finer fabrics and threads will use smaller needles. Silk would probably take a 70/10 or smaller. Regular woven cotton would probably use an 80/12 or 9-/14. Heavier fabric like light-weight denim would probably take a 100/16 or a denim/jeans needle.
SCHMETZ Household Needle Chart SCHMETZ Needles
Mar 18, 2018 | Sewing Machines
Can you sew leather with the Hobbylock 786? Also is a price of $190 good for this machine? Thank you
Difficult to say since we don't know anything about the leather. Generally, a soft, thin leather can be sewn on a domestic machine. However, a thick leather will cause problems. A domestic machine does not do well stitching thick leathers/fabrics. Usually, leather stitching will require a heavier needle, ie a leather/denim needle, which is a size 16. Frequently, manufacturer recommendations limit serger needles to no larger than a 90/12 needle. Using a needle that is too large could strike resulting in broken parts or knocking the machine out of time. Also, sewing thick fabrics places undue stress on the machine. It can cause gears to break or the motor to overheat and burn out. Be aware that a serger trims the fabric as it stitches, so there could be issues with the knives trying to cut the leather.
Guess I am somewhat confused why you would want to use a serger to stitch leather. Normally, a sewing machine that stitches one single line of thread is sufficient for leather. Overlocking uses multiple threads which increases the thickness of the seam.
Mar 17, 2018 | Sewing Machines
How do I sew cloth patches onto jacket. I used heavy duty needle but can not find a setting to use. I have my instruction manual but it is of no help for heavy weight material
I don't know about your specific machine, but in general for heavier fabric, increase the pressure on your pressure foot and reduce the length of your stitches.
Feb 10, 2018 | Sewing Machines
What do you set the tention to when you are sewing denim?
Assuming you're referring to Tension.
This depends on fabric thickness, stitch length, and machine capability. Since you did not note your machine type, needle size, thread specifications and material thickness, it is almost impossible to provide a helpful answer.
If you can provide additional information, we should be able to provide an appropriate response.
Best regards,
Jan 08, 2018 | Sewing Machines
Problems with tension while sewing denim
Most likely it is a problem with the type of needle being used. Use a denim needle or top stitch needle--probably a #14 or bigger. Most likely the needle is not clearing a path for the thread to pass through the fabric, so the thread is hanging up between the needle and fabric. There are needles with a larger "scarf" that shield the thread as it passes through the fabric.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwi9zO2rwvPOAhUMzWMKHfNyDx4QFggoMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
Sep 03, 2016 | Sewing Machines
I'm trying to sew jeans hem and stitches are uneven on top and loops are showing underneath. Also the foot and needle will not sew over cross seams and thread keeps getting snarled up underneath. Tha
a lot of machines struggle with denim because it is such a heavy and dense textile. Many domestic machines won't stitch it at all due to this. Things you can try however:
  • Denim needle, this has a deeper groove at the back and is a heavy gauge needle, or use size 110 if you don't have denim needle.
  • Bash the side seams with a hammer in the area you will be stitching, to soften up the fibres.
  • Use a seam jumper, this is a piece of plastic to put in back of the presser foot as you approach a cross seam to help keep the presser foot pressure even across the fabric. Sometimes called a "thingy-a-jean" or similar.
  • Don't bother trying to use the heavy gauge yellow jean thread unless you put it through the bobbin and sew with the right side down. But even then, many machines can't handle having this heavy thread underneath and the regular 50 cotton on top, my Janome 1600 won't do it.
  • put your machine on slowest speed if you have a variable setting and turn the flywheel to assist it through the heavy side seams.
Personally, I never bother with the twice turned hem on denim if shortening, I just overlock the raw edge, turn up 1 cm and stitch around in a matching blue thread so it is seen as little as possible.
Feb 03, 2014 | Elna Sewing Machines
I have a Bernina Virtuosa 153 sewing machine that is skipping stitches while trying to shorten a pair of jeans. I changed the needle to a 100/16 and am using all purpose thread.
You may need to increase the foot pressure to cope with the heavy denim material. Look carefully at the material as the machine tries to stitch ... if the foot is not keeping the material firmly on the stitch plate, it might be riding up on the needle (denim tends to be rather 'grippy') which will prevent the thread loop being formed correctly below the stitch-plate and therefore not getting picked-up by the CB hook. Changing to a bigger diameter needle might actually make the situation worse in this case ... go back to an 80 and try again.
Sep 17, 2011 | Bernina Virtuosa 150
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Sewing Machines Logo
110 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
