Question about Sigma 18-200mm f/3.5-6.3 for Nikon
Not auto focusing
Brand new 18-200 .
old 18-55 works perfectly.
Can manually focus, but on auto nothing
Don't know what settings if any to use !!!
It could be that the autofocus switch has become unglued from the frame and so it doesn't ever switch on. If your camera doesn't indicate that autofocus is on, but you're not getting an error message, then this might be the problem. Unscrew the two screws that hold the AF switch onto the lens, and see if the underlying PCB upon which the switch is mounted has come loose. If you, take the lens apart from the back and use double-sided tape to re-adhere.
Posted on Mar 24, 2009
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
Have a brand new EOS 100D with Canon image
Have you actually cleaned the contacts or are you just looking at them and they "look" clean? Clean them with a cotton swab lightly dampened in rubbing alcohol.
Feb 28, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Nikon 18 to 55 lens wont focus
Check to make sure the manual focus/auto focus switch on the lens is set to A. Make sure the lens is completely mounted to the camera and locks securely. If this does not help, or if the lens was dropped, then you should consider buying a new lens. the cost of fixing the old lens may be at least half of the cost of buying a new one.
Nov 12, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Monitor auto-focus problem with HP windows 7
Go to the control panel (or it's equivalent) in Windows 7 and reset the monitor for a higher resolution which should reduce the image size. You may need to upgrade the monitor driver files for Win 7 so that 'auto-focus' is enabled.
Nov 03, 2009 | Computers & Internet
Nikon Lenses
They will fit but will work only in manual mode
Jun 14, 2009 | Nikon 50-300mm f/4.5 Manual Focus Lens...
Nikon D40 help?!
I assume the lens had the impact. The 18-55 lens has the built-in motors for auto-focus.
Try switching to manual focus (on the lens). If this works, the lens may not auto-focus anymore.
Try it and let me know.
cheers,
Sep 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Auto focus
you will need a service tech to alien the convergence in the service mode then perform the perfect focus in the service mode to lock this setting in memory.
Jun 21, 2008 | Samsung HCN5527W 55" Rear Projection...
Sigma 18 -200 lens with D40x
This lens is NOT compatible as the body doesn't have a motor . £200 wasted
Jun 08, 2008 | Sigma 18-200mm f/3.5-6.3 for Nikon
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
Sigma 18-200mm f/3.5-6.3 for Nikon Logo
279 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
