Autoshutdown i try to system restore it on the safe mode but it doesn't work also. beacause before i can get there it will automatically turn off
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Posted on Oct 24, 2010
SOURCE:
My computer was set back to factory setting in safe mode now it wont get to windows
I'll recommend you to insert a windows installation disk or windows repair disk
and then press repair computer, make sure your operating system is listed and press next , then launch startup repair, which will automatically detect for the problem that occured while booting and try to fix it and if this doesn't work try a system restore
Jul 13, 2012 | Dell Computers & Internet
Sony vaio lcd screen turns black after start up
graphics card software fault. start the pc and get it to bring up the start menu where you see options such as safe mode,usually holding down f8 when you boot. (If all else fails whilst windows is loading hold down your power button to power it off then it should automatically ask you what to do.)
select restore to known good configuration.
If that does cure it boot to safe mode and do a system roll back (restore) to an earlier time when it did work
If that doesn't work, also in safe mode you can try removing the graphics card drivers and forcing it to load windows default drivers. then update from the website.
If nothing works, not even safe mode then you'll need to use your windows disks or recovery discs. If you fear losing everything then try downloading and burning a ubuntu live disc on another PC and use that to load your laptop then copy and back up your files to another drive or usb stick using the ubuntu operating system.
Dec 02, 2011 | Computers & Internet
I installed a rompaq update on the laptop and it stopped working. what do i do? the laptop is so dear to me. pls help.
if the laptop was working perfectly before you installed the rompaq update, then it means the rompaq is the cause of the problem.
You need to perform a system restore in order to undo the installed rompaq.
Run your system in safe mode and perform the system restore.
To run system in safe mode, Turn on the computer and immediately, start pressing F8 constantly till a windows booting option shows up. Use the arrow key on your keyboard to select safe mode and press enter, then wait for the windows to load completely.
After the computer and successfully booted in safe mode, go to:
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe of your laptop will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jun 12, 2011 | HP Compaq Evo Notebook N410c
Automatic re booting
Welcome to Fixya
Try to do system restore first on safe mode. Turn on the computer and keep on tapping F8 key. Select safe mode and press enter. Once you are already booted up to windows safe mode, click start menu then click all programs. Click accessories then click on system tools. Click system restore then choose a date where you remember the computer is working fine. Restore the computer to that date.
Thank you for usng Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 24, 2010 | Lenovo G550-29583AU Notebook
When I turn on computer it will go to windowsscreen then back to a screen that says windows did not start successfullyit allows me to highlight sart windows shows a 30 second countdown goes to the windows...
Hi. Try to select Disable automatic restart of system failure then press enter key. If same issue will occur, try to boot your computer from safe mode and restore the computer back to date where you remember computer is working fine. Here's the procedure for safe mode.
Keep on tapping F8 key
Select Safe mode
Once you are inside windows safe mode, click start
Click all programs
Click Accessories
Click System tools
Choose a restore date
Let the computer finished the restoration
All the best!
Jul 25, 2010 | Acer Aspire One PC Notebook
Can't get computer out of safe mode
From Windows Safe Mode click Start / Shutdown and restart the computer. This should start the computer automatically back into Normal Mode.
Note: Many users believe that they are still in Safe Mode because the colors or video may not look correct. Unless in the corners of the screen it says "Safe Mode", you are not in Safe Mode.
If you are rebooting the computer and it is rebooting back into Safe Mode (it does say "Safe Mode" in each of the corners), it is likely another problem exists with Windows preventing it from loading into Normal Windows.
If this does not work try: http://www.computerhope.com/basic.htm
Dec 30, 2009 | Compaq Presario Notebook
Just bought an acer aspire ax1200-b1581a.it worked fine for a few days now it will pop up there was a problem with the internet and shut the itnernet down,it started out going blue screen and at the bottom...
I think the problem is related to virus. Try restoring your PC to an earlier date 9 a date when it worked fine). You do this from Start-> Programs -> Accesories -> System Tools -> System Restore. Select
Restore my computer to an earlier time and Click Next. A date calender will appear, select the preferred date and click Next twice. The system will automatically restart when restoration is done.
If u are not abe to run System Restore then you need to enter safe mode by pressing F8 during booting and selecting Safe Mode from the menu that appears. In safe mode you will be asked a question, you have to select no, and system restore will start
If restoring your pc does not solve the problem then you may need to reinstall your OS.
Nov 23, 2008 | Computers & Internet
Boot up problem
Although this is almost always a hardware problem, pinpointing which hardware is the culprit can be a tedious task so before making any hardware changes, assume first that this may be is a software problem. Assuming that you have Windows XP installed as your OS. You can try fixing your system with System Restore. To do this, turn on your PC and press F8 during the boot-up process. Select Safe Mode and login with an Administrator Account. A pop-up window will then prompt you to enter Windows in Safe Mode or just Restore your system by using System Restore, choosing NO will automatically open up the SYSTEM RESTORE window. Choose a restore point (a point or a date where your PC worked well before having problems). Your PC will reboot with the configuration set on your selected restore point. If this doesn;t solve the problem. You can try fixing your system using your Windows XP installation CD. Just don't forget to set your CD as the first boot device.
Nov 13, 2007 | Asrock K7S41GX Motherboard
Computers & Internet Logo
18 people viewed this question
Ekse
Alun Cox
