System error E007 Canon IR2022 - Office Equipment & Supplies
    New Friend:
Hi
I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error E007 .. and some times when i turn on the copier it shows this error .
How can I Fix this error ... please help me .
Thank You in Advance.
Posted on Nov 22, 2011
  • Abdul Jalil Nov 22, 2011
    Hi
    New Friend:
  • 23 Answers
The fixing assy rotation has a fault this could be the film is torn or has move to one end but it will most proberbly need to be replaced. the film unit can be replaced without replacing the whole unit.
Posted on Nov 01, 2010
2 Suggested Answers
6ya staff
SOURCE:
sycherlwe
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
How can I fix an error code E007 on a canon IR2022 copier?
E007
0000-
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause-
The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution-
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO:Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal:5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440 msec OFF
NO:If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES:Replace the fixing film unit.
NO:Replace the DC controller PCB.
Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*)
Try this - Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Jul 16, 2014 | Canon iR 2022 Printer
Ir2022 system error e007 vido
Error Code, Sub Code, Code Explanation E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. Before you change the fixing film, then download and install the newest driver for this printer. If that doesn't work, then check if the paper size is correct. It might be on A4, but you have to check if the dimensions are correct.
This might help with the dimensions
Welcome to A4PaperSize org
Jul 06, 2014 | Canon iR 2022 Printer
System error E007 Canon IR2022 whit is prablume
The fixing film sensor is faulty. Before you replace the fixing film sensor, you might wanna try this first!
Download and install the newest version of the printer driver. If that doesn't help then check the papers size.
If you are using A4, then you have to make sure that it is actually the correct dimensions. the link below might help you with that.
Canon iR-2016 System erro E007
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
Nov 20, 2011 | Canon CLC 1140 Copier
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
Feb 14, 2011 | Canon iR 2022 Printer
Canon irt 2022 says "system error 007"
dear sir !
my canon ir2022 has one problem which is system error E007 how i can solve this above problem , i am wait for your answer .
Thanks & Regards.
Nayeel
Aug 13, 2009 | Canon iR 2022 Printer
Canon IR 2020 showing system Error E007 printer
Jun 16, 2009 | Canon iR 2022 Printer
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Open Questions:
1,814 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
