Question about Cell Phones
MY CELL PHONE IS GIVING EROR OF MESSAGE MEMORY FULL. I HAVE ALSO UPDATED THE SOFTWARE FROM NOKIA OFFICAL WEBSITE BUT STILL THE EROR IS ON ITS PLACE............ WHAT SHOULD YOU SUGGEST THAT I HAVE 2 DO? NOKIA 622O C
    New Friend:
Clear your web browser history (cookies nd cache ) nd also your unnecessary text msgs....:P
Posted on Oct 24, 2010
SOURCE:
Nokia wlan not work erore system erore but this is no system erore
Sounds like a software fault to me.
Go onto NOKIA website and look if there are new updates.
Go into your wifi settings and check your Router is cnnecting correctly.
Mar 01, 2015 | Nokia Cell Phones
In nokia N73 phone camera get autumatically started & also phone memory is full.......not able to receive any SMS
Just try restore factory setting may be your camera problem will get solved if not then you should Update your N73 Software for that you should visit your nearest Nokia care center it will get resolved
Message memory full
Just go to Message Settings Select Others in that you'll find Memory in use in that phone memory is selected you should change it in to Memory card
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 16, 2011 | Nokia N73 Cellular Phone
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
My nokia N95 wont operate it always says"no enough memory to perform operation.delete some data first."although i delete all message in my inbox,phonebook,and everything in the phone memory,still ddint...
Back-up your data first.then insert *#7370# and the phone will restart.If it didn't helped you,use a software update(which is awailable for free on nokia's official website and you're encouraged to do upgrading to have full benifits from your handset)
Sep 02, 2010 | Cell Phones
I keep on receiving a message saying unable to receive message-memory full...but the memory is far from full. I have deleted all my text messages, taken the sim out, battery off,etc. It tells me I have 112...
From what I can see, this is a common issue with this phone. The fix is to update the firmware to the 2.0 version.
Here is the link to the nokia update site
http://europe.nokia.com/support/download-software/device-software-update?n97=
Jan 20, 2010 | Nokia N97 Cell Phone
Not able to send message
I work at o2 in Bury, if you goto nokias website you can do a firmware upgrade for both handsets free of charge. You do need the USB data cable (DKU-2, DKU-5 or CKU5 cables) that came in the box
Support site is here, http://www.nokia.co.uk/get-support-and-software/download-software/device-software-update if there is an availiable update it will reformat your handset with that.
If you want to see if its done this, before you update key in * # 0 0 0 0 # and take note of the Version then do the same once finished. If all else fails, so long as your phone is still under manufacturers warranty you should be able to have it repaired at a Nokia Service Centre located around the UK, you'll find these here!
http://www.nokia.co.uk/get-support-and-software/repair
Hope this helps
Alen Boardman
Feb 12, 2009 | Nokia E66 Smartphone
Memory full problem
The firmware software has got corrupted ...
you should give the "restore factory setting" once ,after you give this option you will be asked for the security code enter that .. and after the restoration is complete restart your mobile once and check it ...
if you still persist the same problem then you must upgrade the firmware software ..
you can do that only if you have the data cable ...
you can do firmware software upgrade by downloading the application from the website given below :
http://europe.nokia.com/A4579163
but remember not to turn off your mobile or remove the battery while updating is in progress ...
regards
-Dileep
Dec 26, 2008 | Nokia N73 Cellular Phone
Nokia 6230
ONCE U REMOVE THE MEMORY CARD AND INSERT AGIAN AND CPY UR FILES EVEN IT IS EMPTY AND U SHOULD COPY THE FILES WITH OUT ANY OTHER FOLDERS OR U SHOULD GO AND CHECK OUT UR PHONE MEMORY PINS OK RATE ME WITH 100%
Jul 08, 2008 | Nokia 6230
Music Player: Not enough memory to perform operation delete some data first
nthing to worry change ur message setting ,put memory card memory as memory in use. after cahnging tht u cn easily save ur files to ur memory card
Feb 19, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
73 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
