Question about Whirlpool LGB6300 Gas Dryer
DRYER HEAT TURNS OFF AFTER ABOUT 30 MINUTES
We have the LGB6200KQ1 model, but I didn't see that listed as a choice on your site. Anyway, we have checked the vents behind the dryer and up to the roof, both are clear. We ran the dryer with the hose disconnected, the dryer heats for aobut 30 minutes, then stops heating. It still turns but stops heating at some point, so the load doesn't finish drying. Any suggestions as to what part is bad?
  • LieslC Jun 07, 2008
    I don't understand the answers given. One of your solutions is even for an electric dryer..ours is gas. We have the dryer out in the middle of the room and the heat still shut off after some time, so it can't be an issue of it being in too cramped of a space.
  • Anonymous Mar 17, 2014
    Dryer stops after 30 minutes of drying time
    Genius:
  • 1,665 Answers
Type in your model number at search tab
Then select at "Part Type' repair manual , circuit board timer or any other part needed
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 07, 2008
    Novelist:
  • 142 Answers
Most likely the problem caused by the coils (#13 & 14 on the burner break down diagram) on the gas valve. They are not stable and do not always holding the gas valve open. Due to this sometimes you will find cool air flowing then followed by hot air and sometimes it stops working at all.
So if u can change the part yourself that would be very well otherwise contact vendor to fix the problem..
- The part number for the set of the coils is AP3094251
Check out this link: This will give you the details and make sure
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=266085
Thanks and Best of Luck and plz dont forget to rate
  • 790 Answers
Sounds like you could have a bad motor
There is a over load on the motor that will kill the power to the motor if the motor gets to hot. Once the motor cools off it will reset and run again.
  • Kanth raj
    Kanth raj Jun 07, 2008
    Check that your drum rotates fairly easy by hand
    Open it up and clean it out, also clean/check the venting
  • 6,487 Answers
  • Get on with replacing the gas valve coils shown to you in the previous link, it will take care of your problem.
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
  • Mark Gil
    Mark Gil Jun 07, 2008
    I just gave all of the possible solution for your problem if some are not applicable just try the others, tanx by the way for the information hopes any of those solution will solve your problem.
  • Mark Gil
Dryer heats for 5 minutes then no heat, but keeps tumbling
Perhaps the flame sensor is not working. If it does not sense heat, it will shut off the gas. You might go online and search for a manual to help you troubleshoot, or go to:
for troubleshooting help and parts. I hope this is of help to you.
Jan 16, 2014 | Dryers
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Have a whirlpool lgb6200kq1 that starts off getting hot but after a few minutes its not hot any more. I can see a glow then a flame at first then just a glow and then nothing after a few minutes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][][
Aug 04, 2011 | Dryers
DRUM TURNS THERE IS NO HEAT
Check out my tips and tricks for gas dryer heating problems. Click on my username and scroll down til you find it listed on my profile.
May 16, 2010 | GE DBXR463GB Gas Dryer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
The dryer heats up but turns the heat and timing
usually the coils on the gas valve are going out
Oct 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Kemore Dryer / Model # 63742
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
May 16, 2006 | Kenmore 64742 Electric Dryer
Whirlpool LGB6300 Gas Dryer Logo
117 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
