Question about Kenmore Microwave Ovens
Power is on, but display reads 5E, or SE. No other dislay can be activated.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 93 Answers
Fuse
Posted on Oct 24, 2010
6ya staff
SOURCE:
-se- is displayed on the screen, what does it mean?
Usually means "Sensor error". The problem is usually associated with the circuit board for your touch pad on the front of microwave. More than likely a bad contact/connection on one of the plugs in the back of that panel.
Just type the following in your search engine and the video explains it all. "samsung microwave se (5e) error fix". Hope this is your fix and that you are OK with taking it apart. MAKE SURE ALL POWER IS REMOVED BEFORE GETTING IN THERE!! good luck!
Oct 08, 2015 | Samsung Microwave Ovens
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
Microwave started beeping with nothing in it now it says SE or 5E
These issues are usally due to a defective touchpad or control board. Troubleshooting would require disconnecting the touchpad ribbon cable from the control board to see if that made the problem go away.
Jul 17, 2014 | Microwave Ovens
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
5E display on maytag microwave
<- Let me know your full model number from the tag on your oven so I can give you detailed information repair.
Unless there is grease or moisture on your control circuit board, "SE" means you have a shorting membrane keypad.
Jan 05, 2014 | Maytag MMV1153A Microwave Oven
Tappan microwave has se or 5e on diplay wont push buttons
this a problem a dust in the control board keypads, You must open the keypad, and clean any connector with contact cleaner specially the ribbon cable or plastic and use pencil eraser for to fix the corrosion, dust, and try again.
Jul 08, 2013 | Microwave Ovens
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
Says se on display
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement, if it has already been replaced then it is better to replace the ribbon cable connecting the board. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Frigidaire FGMV174K Microwave Oven
Samaung microwave, model # SMH7174WE, when you plug it in, it will read ***SE***. It was made in 2005, S/N 7MTY900412X
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Microwave Ovens
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
